Moved question re Purge Valve for 4.0 litre
Old May 27, 2022 | 11:44 AM
Don Elliott's Avatar
Default Moved question re Purge Valve for 4.0 litre
I posted a question in the wrong cubby hole last night so here's a try at the right place. My kitty-car is a 1997 XK8 with the 4.0 litre engine. She needs a new purge valve which is part of the gas tank vapor recycling system. I cannot find one anywhere. The closest is a back order on top of a back order at a Range Rover shop. A previous poster recommended Rimmer Bros, SNG Barratt, and Welsh Enterprises. My mechanic wizard is now tracing those down. Are there any other place I should look? Many thanks.
Don Elliott
WA State
Old May 28, 2022 | 11:49 AM
Robin Smith's Avatar
Try...
Jaguar Palm Beach
Just as a matter of interest, what are the symptoms of a faulty purge valve?
Old May 28, 2022 | 11:52 AM
https://parts.jaguarpalmbeach.com/p/...LJA1515AA.html
sorry, trying again...
Old May 28, 2022 | 12:35 PM
motorcarman's Avatar
Might all be the same from 4.0 X100
Old May 29, 2022 | 11:07 AM
Default Symptoms of a purge valve failure
The main symptom is the illuminated CHECK ENGINE lamp. It might lead to poor gas mileage but that's about it. It starts and runs as it should.
Old May 29, 2022 | 04:27 PM
What DTC is logged?
Old May 30, 2022 | 11:22 AM
Default Sourcing a purge valve
Sorry I do not know what code was thrown as my mechanic did not share that information. But the tip to check out Jaguar Palm Beach Florida parts may have been a valuable tip but as everyone has been closed due to the holiday I won't know until later this week. Anyway thanks for the tips. Maybe the FERLCAT only used up one of her lives on this incident.
Don
Old May 30, 2022 | 12:58 PM
DTC is important because many people confuse the CCV with the purge valve. (two different animals having to do with the EVAP system)
Old May 31, 2022 | 10:37 AM
Default What Code is thrown on a Purge Vale failure
So what code should I look for if the purge valve is dead or the CCV?
Old May 31, 2022 | 12:26 PM
If ANY DTC is logged other than P1000 or P1111 you need to write it down and look it up!
Old May 31, 2022 | 01:00 PM
kstevusa's Avatar
Don, may we suggest taking the car by a Auto Parts store (Autozone, O'Reilley's) type and ask them to read codes and write them down. Then let us know the ALL the codes. This should point the search in correct direction.
Old May 31, 2022 | 01:12 PM
tmattson57's Avatar
I have a working purge valve and CCV from my 2002 xk8 if you need them. PM me.
Old Jun 1, 2022 | 07:42 PM
Default Status of the Purge Valve search
Confirmed that the displayed code is indeed the purge valve so the search is on for a new part. Palm Beach Florida does not have one. Drat!. Found one in Vancouver BC so that is now the focus of trying to import it. We are not far from the Canadian border, but the import rules are inflexible. The used valve in Northern CA is "on deck" in case the BC part cannot be accessed. Tricky business this. Stay tuned.
Don Elliott
Old Jun 1, 2022 | 08:17 PM
Still will NOT tell us the DTC.
Old Jun 2, 2022 | 05:54 AM
kstevusa's Avatar
Top secret ??
Old Jun 2, 2022 | 06:19 AM
JayJagJay's Avatar
Don Elliott
Folks here will tell ya a lot,,, of ya give a little...
What part is the car (codes) alerting you too and calling for?
Also, there are a LOT of directions one can go in getting hands on parts (for a LOT cheaper, more readily available),,, I would help, but ya AIN'T giving us the information we are all asking fo,,,, my Man... Man O mystery
Old Jun 2, 2022 | 11:05 AM
Default What secret?
P-1111. Just as predicted.
Old Jun 2, 2022 | 11:41 AM
JayJagJay's Avatar
If your car has the CEL (check engine light) illuminated there most has to be a code stores that is directly related to the CEL. If that number (Pxxxx) is given, there is a good possibility that folks here can tell ya what ya need, where to get it and the process for fixing it... and what NOT to allow with your mechanic... Jus say'n
Old Jun 2, 2022 | 11:50 AM
Originally Posted by don elliott
p-1111. Just as predicted.
see post #10
Old Jun 10, 2022 | 04:30 PM
Default Purge valve found but now what about an ABS Control Module
A new purge valve is now in hand from Canada and will be installed next week. But my car continues to also report Stability Control Fault displays which ties to the ABS Control Module failure (ABS c-1155 left front speed sensor. But this sensor has been replaced more than once and the control module itself is suspect.) This has been a chronic failure for the past 5 years and no amount of re-soldering or tinkering with the present module has resulted in a long term fix. The brakes are fine but the ABS function is likely disabled. So I have given up on patches and fixes.
This week I came across a flyer from JagBits of Goleta, CA which claims that they can "rebuild" the module for $500 with a one week turnaround. Has anyone used their service with good effect?
Don Elliott
Gig Harbor
