moving gauges
Old Nov 15, 2013 | 08:22 AM
Jen & Neil's Avatar
Question moving gauges
Hello everyone,
Our XK8 has the 3 gauge set up in the center stack and I am toying with the idea installing a double din head unit there and moving the gauges down to were the single din unit is now. I had a quick look behind the gauges yesterday but couldn't see much. So just wondering has anybody done this and any words of wisdom on doing it without messing up any electronics?
Neil
Old Nov 15, 2013 | 08:37 AM
WhiteXKR's Avatar
Originally Posted by Jen & Neil
Hello everyone,
Neil
You will need to cut off the 3-gauge harness connector, leaving a 1 inch or so pigtail on each of the 13 wires. You can then splice in extension wires. If done carefully (with battery disconnected) it would not cause any problems.
Old Nov 15, 2013 | 08:55 AM
Jen & Neil's Avatar
thanks, but what is behind the gauges, I saw wires there but whats the best way to cut through the backing so a double din chassis will fit?
Old Nov 15, 2013 | 09:09 AM
WhiteXKR's Avatar
Mechanically this will be a bigger challenge. I believe there is HVAC ductwork behind there.
A better/easier solution that others have done successfully is to relocate the row of console buttons in the glovebox and mount the double-din in exisitng the radio location.
See https://www.jaguarforums.com/forum/x...ot-work-75254/
Old Nov 15, 2013 | 09:14 AM
Jen & Neil's Avatar
oh well that could **** on that bonfire then!! anyway I will try to strip out what I can so I can get a better look. If it looks like it can be done I might me tempted to post pics on the project. Thanks for the input.
Old Nov 16, 2013 | 05:05 AM
Beav's Avatar
Even when installing the DD in the original spot there will be a little heating and mooshing (technical term) of the ductwork in order to install. The upper spot is pretty shallow.
This was my original install. I've since reverted to the original switchpack in the glovebox. However, I do have parts and a plan for returning the switches to the surround, just a better looking way than shown here:
https://www.jaguarforums.com/forum/m...adio-12394.jpg
I also changed the change tray to a center speaker grill as this unit has DD5.1 and DTS.
Poet
Oct 6, 2015 09:40 PM
10 XF Premium
Sep 19, 2015 08:48 PM
tsimms7
Sep 15, 2015 12:43 PM
1100me
Sep 7, 2015 06:26 AM
Bcrary3
Sep 3, 2015 03:48 PM
