MPG going down
Old Mar 4, 2008 | 07:15 PM
n17gary's Avatar
Default MPG going down
2001 XKR with 23K miles--When I picked up the car last April I was averaging ~18mpg. I am averaging ~15mpg now. No difference in driving or performance. I know the plugs are original and I plan on changing them when the weather gets a little warmer.
Are the plugs the probable cause being 7 years old even though not much mileage on them?? Any other suggestions such as EFI adjustment
Gary
Old Mar 4, 2008 | 07:21 PM
FactoryJaguarTech's Avatar
Default RE: MPG going down
No adjustments. Clogged air filter? Part load breather clogged? I would suspect air delivary before spark. If not running rough, likely not plugs. But no harm in changing them anyway.
Old Mar 5, 2008 | 02:09 AM
H20boy's Avatar
What kind of fuel are you feeding her? Race Track 89 Octane...or Exxon/Shell/Mobil 93? this made a huge difference in prior vehicles. Can you borrow a scanner with real time O2 sensor readings? That can tell you if you are running too rich...could be a sensor going bad.
Old Mar 5, 2008 | 10:00 AM
GordoCatCar's Avatar
O2 sensors is my "guess" since I have little experience with AJ26/27 engines.
PS THX H20 4 PM MSG - G
Old Mar 5, 2008 | 06:21 PM
n17gary's Avatar
well some good suggestions--I have been running plus (89 octane) performance has been fine. I have hecked the air filter--didn't seem clogged but I will change anyway. I have no access to scanner so maybe I will get the o2 sensor checked--would a bad O2 sensor give me some sort of error message or light
gary
Old Mar 5, 2008 | 06:39 PM
jag_genius's Avatar
winter gas?
Old Mar 5, 2008 | 10:02 PM
H20boy's Avatar
ORIGINAL: n17gary
Fuel filter check/changed also...running 89 octane may be your problem, manual recommends 91 as a minumum. Just saying.
As for the O2 sensor, I think it has to be constantly out of spec, and perhaps it isn't doing it enough for a MIL to appear, but a DTC code may have been thrown, won't know until you check w/ a scanner. A technician care to elaborate?
Old Mar 6, 2008 | 04:46 AM
O2 sensors will flag codes almost immediately due to emissions regs.
89 octane will definitly show loss of mileage. Spend the extra $3 per tank and you will see a noteable difference after a few fill ups. Also clean you injectors if you have been running cheaper gas through them for a while.
Old Mar 6, 2008 | 06:11 AM
H20boy's Avatar
^^ yah, I was going to say that too. Really.[sm=smiley24.gif]
Old Mar 6, 2008 | 11:24 AM
Whats the effect of 89 octane?
Does ECU pull back on timing? Thus causingengine to drop out of optimal power curve?
gordo
tampamark
Oct 11, 2015 10:03 PM
buickfunnycar.com
Oct 5, 2015 02:41 PM
Delta66
Oct 4, 2015 05:40 PM
mat32essex
Oct 3, 2015 04:12 PM
