My new 2001 XKR Issues
As for resetting the settings................. Have a read........... Click Me To See How To Reset The Settings.
Good luck. Looks like a nice car you have there.
Plus one on the battery. The Interstate Megatron is to be a good replacement. It worked for my car, which had a myriad of lights, codes, and inoperative systems. Find the hidden key hole for the boot lid and make sure your key opens it.
Looks like a beauty!
Question. How will I know if the secondary chain has slipped a tooth or two ?
Well bad timing typically shows as a rough running engine, if you're familiar with the engine sound, and in the old fashioned cars, a "coughing" engine typically needed a tune up. Unfortunately this is not possible with modern GDI engines. I've never set the timing on the AJ-V8 engine but I know there are specialist tools needed esp. as there are no TDC marks and you need to lock the flywheel at 45ATDC. More experienced Forum members will chime in, if you need to do this.
If you hear pinging STOP! as it's an interference engine and you can cause all sorts of problems. Check out Sklimii's excellent 2018 thread on his experience with horror pics. Post #27 has pics by BobRoy, with Sklimii showing Gen1 tensioners in Post #38 (plastic bodied)
https://www.jaguarforums.com/forum/x...0/#post1849908
When driving, you should have a noticeable lack of power, and sluggish response. Wouldn't be surprised if the CEL comes on, and if you have a OBD2 reader, it should engine errors with bad fuel trims, and exhaust emissions.
https://www.jaguarforums.com/forum/x...19/#post713091
R L
26
Apr 18, 2019 10:24 AM
muskox3437
22
Apr 27, 2017 03:08 PM
Neptun
24
Apr 24, 2017 08:48 PM
Mark in Maine
Feb 3, 2016 06:19 PM
