Need answers to 2 trans code questions...
Old Jul 12, 2014 | 05:57 PM
JessN16's Avatar
Default Need answers to 2 trans code questions...
After having searched the forum, I just want to make sure I understand this correctly before proceeding.
My car is throwing a code for improper Transmission Range (believe it's p0706 if I remember correctly; car is doing the "Gearbox Fault" thing about once a week). There are no shifting/running problems.
Today, I noticed that when the fault tripped, I lost illumination of my J-gate selector. Meaning, no lighted "P", "R", etc. So the questions:
1) This is most likely a rotary switch fault, correct?
2) Will the transmission have to be dropped to access the switch?
Thanks,
Jess
Old Jul 12, 2014 | 06:40 PM
motorcarman's Avatar
P0706 Rotary switch and/or D–4 switch malfunction.
Possible Causes:
Selector cable adjustment / installation incorrect.
D – 4 switch dislocated.
D – 4 switch to TCM circuit open circuit or short circuit to ground.
D – 4 switch failure.
Rotary switch to TCM circuit open circuit or short circuit to ground.
Rotary switch failure.
The rotary switch is bolted to the right side of the gearbox.
bob gauff
Old Jul 12, 2014 | 10:47 PM
JessN16's Avatar
Thanks Bob. Does the trans have to come down to get to the rotary switch, or can we see it/change it with the car in the air?
Jess
Old Jul 13, 2014 | 03:29 AM
JagV8's Avatar
Probably not. See if a bolt is loose/missing. If this is the S-Type, quite common & definitely does not need box out. Trivial to fix.
Old Jul 13, 2014 | 04:34 AM
ArtyH's Avatar
Just had one changed on my car, it was done in a garage while they were checking other matters. I took one off a spare box, was held on by two small bolts on a bracket and one bolt which activates the mechanism. If you have the car on a ramp or axle stands it should be doable, and only take at most 10-15 minutes to change.
Old Jul 13, 2014 | 08:14 PM
JessN16's Avatar
This is on our XK8. Unfortunately, I've thrown the white flag on the S-Type.
Jess
silkcat
Jan 18, 2025 04:29 AM
Adam Lueb
Sep 28, 2015 02:54 PM
SeanU
Sep 18, 2015 08:09 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
