Need current upper shock mount supplier and whether new shock or just lower mount
Old Nov 7, 2011 | 02:14 PM
oldjaglover's Avatar
When I got to playing with the rivets I ended up just pushing the shafts out the other side and voila...no more "pokies" to worry about. The small drilled hole in the center bearing is puzzling, though.
Old May 10, 2014 | 04:52 PM
mudjag's Avatar
Default upper shock mount removal replacement
referring to the upper shock mounts rebuild replace
you must have an inpact wrench to take apart the nyloc nut on the shock shaft
and you will likely need a "jounce bumper" ($25 dollars each at bapgeon) if they are rotted away like mine. Also removing the bolt from the upper a arm is a liittle harder than shown, I finally had to use a a screwdriver to pry it out and get it started. Also removed the upper ball joint to get some movement. there is a universal press that you can get at sears for 20 bucks that takes it right off no pickle for me no sirree. Even then it was a hour or two working it out. the black dog replacemt instructions are not clear and look like a copy of a copy so its hard to tell how and which goes where. Since i live in houston and i have to wait on the unmmentioned jounce bumper i might drive by there to make sure i have it correct on monday
Old May 11, 2014 | 06:34 AM
cjd777's Avatar
Default jounce bumper stops
Mudjag, I got a nice set of bumper stops and dust covers from Advance at $21 a set (SB101) is the part #.
Wayne
Old May 12, 2014 | 08:01 AM
mudjag's Avatar
thanks for the tip
read the reviews on the advance website
some good (rubber)some not so good (pvc)
Old May 12, 2014 | 04:03 PM
cjd777's Avatar
Default shocks
Mud, I too read those and really didn't see what difference it made.
After getting them in and comparing with OEM the PVC was some what firmer and the bump stop fit was good. I will just have to let you know if they stand up as well in 60K miles as I'm sure the bottom shock mount will be junk, should have been poly to start.
I did a write up a couple of weeks ago called "Front shock replacement part 2" which was some of the problems I had, not a easy job by any means!!!
Wayne
Old Jan 18, 2019 | 03:35 PM
CleverName's Avatar
Problem with that is that you do not know if the rivet actually flared the lower portion enough to be considered effective. If you have a micrometer, you should compare the two to be certain.
Vince
Old Sep 24, 2019 | 12:52 AM
TheBaltimoron's Avatar
My poly front shock mounts were $150, front bushings are under $40/pair, not sure about rears.
https://www.ebay.com/itm/Jaguar-XK8-...D/311509183326
ym37tech
Feb 8, 2016 01:04 PM
1964Daimler
Sep 9, 2015 11:28 AM
EZDriver
Sep 8, 2015 09:25 AM
Tar
Sep 6, 2015 11:24 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
