Need a head light lens
Old Mar 3, 2020 | 12:59 PM
DBC's Avatar
DBC
Default Need a head light lens
The outer headlight lens for my drivers side headlight broke and I need to replace it. I find a YouTube from a guy where you can replace just the lens. I do have the washer sprayers but how do I tell exactly which head lights I have? HID, Xenon.
Old Mar 3, 2020 | 01:48 PM
fmertz's Avatar
On an '05, you most likely have HID. You can test it by turning them on. Conventional Halogen turns on "instantly", whereas the HIDs take a second or so to come to full brightness.
Old Mar 4, 2020 | 09:11 AM
DBC's Avatar
DBC
Okay I must have HID because I noticed a when I first got this car that when you turn on the headlights they appear to open up from the bottom up as if they are stowed down in a closed position. So if that's the case then I just need to look for an HID head light with the wiper spray option?
Old Mar 4, 2020 | 10:24 PM
bcprice36's Avatar
DBC in Oak City,,,
Your 2005 XK8 came from the Factory with HID Low Beams and Halogen High Beams...Your description of the Low Beams coming-up when you turn them on fits the HID's perfectly...If the outside Glass Cover is broken you will need to find a good one in a Wrecking Yard or buy the whole Light, which was made by Genuine. I saw where you could buy a new one from CarID or you can get them from Dave in Scotland....https://www.xk8-parts.com/contact-us/ Dave is also a source for the Black Rubber Gasket that goes between the headlight and the Fender. Jaguar doesn't sell these anymore!
Billy Clyde in Cinco Ranch
Old Mar 5, 2020 | 05:48 PM
frankc's Avatar
Tip for you. When you have removed the headlamp to swap the front bit over first heat the clips with a hairdryer etc. If you do not soften them first they will snap.
You will also find the screw underneath the headlamp a real bar steward to remove. Id advise cutting the head off it and not replacing it.
Old Mar 5, 2020 | 05:50 PM
frankc's Avatar
The one that should be here.
This was on the other side of my car. Not removed, obviously.
Jspann07
Oct 18, 2016 09:31 AM
bassmania
Mar 14, 2015 04:42 AM
talashek
Dec 24, 2013 11:19 AM
Xx_Four_Stroke_xX
Jan 9, 2011 04:27 PM
May 28, 2007 10:29 AM
