Need Help! My passenger door window has a 1" gap between it and the rear glass
Drivers door window gap is normal above
It's on my 01 XK8 Coupe I bought last month. The gap is so wide it's leaving an open space right at the rubber window seal.I can stick a finger between the gap. I noticed it when my friend riding with me felt air coming in and thought he didn't shut the door good. I took the door light plastic lense off at the bottom rear of the door and adjusted that middle screw both ways but that didn't help. The window needs to come back towards the rear quarter window. Here's some pics. The drivers door is normal as you can see. What's the solution to fixing this? The window rolls up normal but it is sitting an inch forward.
I can't imagine that the front would seal if the window was moved back to match the driver's side. The JEPC shows a different part number for the door glass for a coupe as opposed to a convertible. Perhaps they are slightly different lengths, and the glass was broken and replaced with a convertible part. Can you measure the length of the right and left sides to see if they are the same?
Hi Jaguar XK8er, I had the same problem and called someone that came home and fixed it in about 5 minutes (The easiest $200 he might earn in his entire life).
When you dismantle the door, you will find a nut in its center. After you loosen it, put the glass in the correct position and readjust. I'm sure someone more competent than me in this forum (like 99.9% of the members) will explain it to you way better than me. I hope it helps!
mjh097
May 24, 2022 09:27 AM
al_roethlisberger
Interior
Jun 24, 2016 05:00 PM
97 Xk8 mayhem
Jun 16, 2016 10:56 AM
Shelby676
Feb 16, 2015 09:43 PM
