Need help with my XK8
Old May 25, 2022 | 08:36 PM
Jodimarie's Avatar
Default Need help with my XK8
Hi an looking for a throttle position sensor for my jaguar xk8 if anyone could help me find one or has one for sale as I have tried to fix my car multiple times w multiple mechanics I have replaced throttle body,fuel pump,gauges,spark plugs,computer it reves at 2500 when started then get poor performance and fail safe obd reader says tps sensor thanks
Old May 25, 2022 | 10:50 PM
Gator8's Avatar
You might want to try the X100 forum; this forum is for 2007 and newer cars. Good luck!
Old May 26, 2022 | 02:26 AM
Jodimarie,
I've moved your question from X150 (2006 - 2014) to X100 (1996 - 2006) forum. Members here with the same model will be able to help.
Old May 26, 2022 | 02:48 AM
Pistnbroke's Avatar
Please tell us what country you are in in the location slot of your details so we can talk in $ or £ . If in the uk its no problem to get parts.
Old May 27, 2022 | 05:03 PM
Gus's Avatar
Gus
It could be that the TPS plug just needs cleaning. Be sure to disconnect the battery before removing the plugs on the throttle body.
Old May 31, 2022 | 04:45 PM
Jodimarie's Avatar
Default Help xk8
Hi everyone tjanl you for the replies it's a 97 jaguar xk8 can't find a tps sensor anywhere for this cat or anyone to work on it I've changed everything bit no avail I need instructions on how to check of tps is getting power and instructions how to clean the tps sensor please
Old May 31, 2022 | 04:46 PM
Jodimarie's Avatar
I am in united States of America Cinnecticut area
Old May 31, 2022 | 04:56 PM
Gus's Avatar
Gus
Your TB will look different than the one on my 1999 but cleaning the plug contacts would be the first thing I would do.
JagRepair.com - Jaguar Repair Information Resource
Old Jun 1, 2022 | 12:32 AM
Pistnbroke's Avatar
I saw a programme on the xk8 with a faulty TPS and they had to change the whole throttle body ( second hand) but of course you need to be sure of the wiring . I understand that it has two sensors on it, They had someone run a diagnostic on it to confirm. Not on US tv
Paulbaessler
E type ( XK-E )
Jan 7, 2026 12:58 PM
Jeanne Nickel
Aug 21, 2021 07:02 PM
Jeanne Nickel
Aug 17, 2021 08:45 AM
D8DTM
Aug 8, 2014 04:30 AM
tvstarmaker
Jun 17, 2008 12:40 AM
