Need information on setting timing.
Old Jan 8, 2015 | 09:29 PM
joegreen's Avatar
Ok i got it. I was just a little confused about where the crankshaft locking location was because some other places on the internet mentioned two different places. I am going to work on it this saturday. Thanks everyone for all your detailed and timely responses.
Old Jan 9, 2015 | 02:54 AM
DevonDavid's Avatar
Joe,
I suspect the confusion is because the "special timing tool" which fits in place of the CPS must NOT be used to lock the engine to remove the crankshaft pulley (harmonic damper) - neither the tool, nor the flexplate are strong enough to take the torque required. So ..... there's another special tool which fits on the crankshaft pulley (harmonic damper) to get this off. I think you will find that this is the only really difficult part of the job - access is limited, and even when the nut is loose, it's sometimes very hard to shift the damper.
Best of luck - let us know how you get on !
Old Jan 9, 2015 | 12:07 PM
joegreen's Avatar
Ok got it, I will not use the crankshaft locking tool when removing the pulley from the crankshaft. Cool thanks guys.
Old Jan 10, 2015 | 06:14 PM
joegreen's Avatar
Ok so the timing chain broke while the car was idling. That definitely contributed to not bending any valves. The car has 60,000 miles and not a spec of rust. We replaced the whole timing chain setup with the new metal tensioners and guide rails. Now all the covers have to be put back on. Thanks for all your help. I didn't take many pics but will post up a few.
Old Jan 10, 2015 | 06:46 PM
joegreen's Avatar
pics
Attached Thumbnails Need information on setting timing.-2015-01-10_12-00-48_418.jpg   Need information on setting timing.-2015-01-10_12-00-56_213.jpg   Need information on setting timing.-2015-01-10_12-30-57_402.jpg   Need information on setting timing.-2015-01-10_12-31-03_618.jpg   Need information on setting timing.-2015-01-10_12-31-46_55.jpg
Old Jan 10, 2015 | 06:58 PM
test point's Avatar
Congrats! Nice clean engine, glad it survived.
That was easy wasn't it. $2500+ at the dealer.
Be sure to send off for your 'I changed my own tensioners' medallion.
Old Jan 10, 2015 | 10:48 PM
joegreen's Avatar
It was very easy. Once everything was locked down it was a snap especially because we had 2 cam locking tools, one for each side. the worst part is removing and replacing the hood and radiator and all that stuff. My friend bought a kit that comes with all of the tools needed ( both cam locks, 2 types of crankshaft locks, wedge tool for tensioning the chain, exhaust cam wrench thing, and the vvt wrench thing. We do not need it anymore so he is probably going to sell it on ebay. Maybe someone on here would like to buy them? What is the " i changed my own tensioner" medallion"? This is NOT the kit he is selling but the kit he has is the same kit. http://www.ebay.com/itm/like/1515409...lpid=82&chn=ps. What would be a good price for the kit?
Old Jan 14, 2015 | 07:20 PM
  #28
Dennis M's Avatar
Would like to buy your cam tensioning tools. 2000XK8 49K Going to change my cam chain tensioners, water pump, and thermostat this spring as preventive maintenance. Can I get all these parts in one kit and if so where? Should I get Jag parts or a ford kit for the 3.9 lincoln engine? How much for the tools? I seem to be hooked on these cars and hope to buy another one, or two depending on wife.
Old Jan 15, 2015 | 04:57 AM
test point's Avatar
Yeah, we sorta like them too!
May I suggest that since you are are upgrading the coolant system that you add the following to the list if they have not been addressed. Your car is 15 years old and needs attention to rubber/plastic parts.
Thermostat tower changed to aluminum . . . paint it black. The original plastic one is going to leak at some point.
Radiator cross over pipe. The original plastic is going to leak at some point.
Upper and lower radiator hoses as well as the short hose from the cross over pipe to the thermostat tower.
Not really a kit available that I am aware of. The Ford/Lincoln tensioners as well as the gaskets are just fine but the rest of the stuff is Jaguar specific as far as I know. FelPro Lincoln gasket sets are the best deal. I recently did all this and shopped the internet for prices and found that SNG Barratt, this forum's sponsor, had the best prices after their member discount. Ask for their catalog as it is a great technical reference.
Old Mar 4, 2015 | 04:22 PM
  #30
joegreen's Avatar
Today was the first start up and it runs great.
Old Mar 4, 2015 | 05:50 PM
  #31
Gus's Avatar
Gus
Kudos to you!
Old Jun 10, 2015 | 08:06 AM
  #32
bowmanec's Avatar
Thank you!!! This was exactly what I wanted to know.
-Craig
trosty
26
Dec 18, 2022 06:40 PM
XJsc-guy
Nov 23, 2015 01:56 PM
34by151
Sep 6, 2015 05:14 PM
philwarner
Sep 5, 2015 10:05 AM
colorancher
Sep 3, 2015 02:29 PM
