Need a little advice - New Engine
Guest
Posts: n/a
I'm a "soon to be" member of the Jaguar community. I've read most of the newbie information posted in previous threads. I'm looking at a '98 with about 85K miles. The car appears to be in great condition, but has a new engine. The engine was replaced at a Jag dealer and the seller has invoices to support his story. ($9500 job.. whew!). He says it's the second generation V8 with metal timing belt tensioners. I've owned a Fiat Spider and most recently a Mercedes CLK. Hence, I'm ready for the unreliability and expensive trips to the dealer. However I've never been faced with a complete engine replacement. The new engine has been in the car for 2 and half years and 20k miles. Should I be concerned or excited that the major engine problems have already been addressed? What could I be missing? Any help would be appreciated!!!
I wouldn't worry about the engine tuck. In 2006 (conservatively) the dealer would have had the new timing chain tensioner issues well in hand and if the engine is a new build (not just a drop-in from a previous 4.0) then it should be ok. Maybe a jag mechanic can give you a little more assurance.
Test out the transmission really well. A small lurch is expected. Those earlier 5-speed transmissions do have a little less longevity than the 6-speeds and I've read where higher mileage transmissions have given up.
Guest
Posts: n/a
Thanks H20. One additional question: If I go with a model that has the original 4.0, is it worth the $$$ to have the tensioners updated with the newer/metal part? In other words, do the plastic tensioners really present a significant risk of failure? Thanks for your help.
They're gonna fail, it's just a matter of time. i would definitely do the tensioners and consider it part of the purchase price. If they fail and break apart into little pieces it'll cause more damage further in and cost more than just replacing them.
