Need to rent/buy tools for tensioners
Old Jan 15, 2012 | 05:28 PM
doc18015's Avatar
Default Need to rent/buy tools for tensioners
Hello,
Decided that after reading loads of threads, that the best approach would be to rent or buy the tools. Anyone have a set for either ....close to Pa? Thanks for the help...finally getting the ***** to tackle this job
Old Jan 15, 2012 | 05:29 PM
avt007's Avatar
Do a search, I saw a post in the last few days where a forum member was willing to rent his tools.
Look here- https://www.jaguarforums.com/forum/g...ls-rent-45101/
Old Jan 15, 2012 | 07:32 PM
Fla Steve's Avatar
Default Tools
I have the tools for rent..too tired to elaborate right now but I will tell you more later. Basically I rent them for $100, request a $250 deposit and charge $25 shipping handling. So when I get them returned I return $125.
I have 2 cam locking bars, the flexplate/crank lock pin, the tensioner/chain spacer and cam gear wrench. They cost me $450 to buy and I'm just recouping my costs.
Steve
Old Jan 15, 2012 | 09:29 PM
Gus's Avatar
Gus
You do know that you have another option in replacing the tensioners without using the special tools.
Old Jan 15, 2012 | 11:22 PM
Bamaman's Avatar
+1 with Gus.
You can cut a copy of the Nylon Tie method of replacing secondary camshaft tensioners and an independent car mechanic can use them to do the job--even if he doesn't have Jag experience. By now, all good mechanics are familiar with overhead cams--chains and belt style.
I'd just hate for you to tackle the job if you were not comfortable doing it. I think that after you get into this method of tensioner replacement, it would all come together for you.
But, it's like opening a can of worms in that we must sometimes change the spark plugs, replace the plastic thermostat housing, replace the thermostat and inspect the water pump for plastic blades. The radiator hoses and serpentine belt pulleys must also be inspected closely. These are all do-able job tasks for most people.
Good luck!
Old Jan 16, 2012 | 07:21 AM
doc18015's Avatar
I have read about both the tie wrap and the factory (tools) methods. The tie looks on the surface the easier way to go but has some problem areas such as cam removal/lift, possible breakage of cams and bolts and lack of perfect timing due to stretched chains; does not address the valve pressure on the cam lobes.
The factory method takes into account the timing issues via chains being streched, one bolt ( not ten) on cam to remove and retorque, no chance of cam bearing surfaces not aligned or lubed.....just seems to be better way.
Just my thoughts.....
Old Jan 16, 2012 | 07:40 AM
doc18015's Avatar
Does anyone know about this method? I just read that the chain can be replaced with a linked chain. This would enable no disassembly, new chain(s) and add new tensioner(s) when the chain is being installed. No tools.
Sounds too easy or has problem areas?????
Old Jan 16, 2012 | 07:52 AM
WhiteXKR's Avatar
You really do not need to replace the chains unless they have been stretched by jumping a tooth or the car has very high miles. Personally, I would steer clear of aftermarket master link chains....there is too much at risk.
This thread discusses pros and cons of both tensioner methods. https://www.jaguarforums.com/forum/x...ion-faq-37415/
Old Jan 16, 2012 | 08:31 AM
Paul Pavlik's Avatar
There is NO Change in the Timing with the Tie Wrap Method.
Old Jan 16, 2012 | 09:02 AM
doc18015's Avatar
Hi Paul and thanks,
My understanding is that even one tooth off will just be replicated by using the tie method whereas the factory method CORRECTS that deviance. Still even if correct as you comment, still have all the other issues .
I have not ruled out the tie method, but my car has 80,xxx miles on it with the original tensioners . No noises, etc. The local Jag dealer says to not do anything until warning signs appear. From this forum , we know that that their recommendation is not good. Same guys that want $4500-$5500 to do all tensioners and pump.
i would like to try the tie method. My car runs great ; timing should be dead on. Still thinking; got all parts on Saturday so day is at hand. Thanks again.
Old Jan 16, 2012 | 09:23 AM
EZDriver's Avatar
Using the zip tie method and lifting the exhaust cam is a piece of cake once you get the cam covers off. The attached link covers the method with pictures and also covers the solutions I came up with in getting the cam covers off. The exhaust cam will come loose easily if you undo the bolts slowly and evenly a little at a time. I think it would also help if the engine was stopped with the cam flats on pointing up.
EZDriver
https://www.jaguarforums.com/forum/x...ics-faq-52653/
Old Jan 17, 2012 | 05:46 PM
doc18015's Avatar
I certainly thank you for the info. I am back to trying the tie method. Will keep advised but seems doable for me.
mikiep
Dec 20, 2019 07:37 PM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
millertic
Sep 30, 2015 08:11 PM
