New window glitch
Old Jan 7, 2018 | 08:26 PM
Kitty Paws's Avatar
Default New window glitch
My 1998 XK8 convertible's driver's window (US) does the proper drop when opening the door from the outside, but fails to go back up when the door is closed. Ideas?
Old Jan 7, 2018 | 09:05 PM
Johnken's Avatar
Kitty (is that what you like to be called?), I have a 98 too. First thought is door switch.
Do puddle lights on that door light properly? (On if door open, off if door shut)
Does drivers door open/ Red light display under Speedo in message center, when ignition on, door open?
The car may think the door is shut, no puddle lights go on, no door open message. These are both connected to the operation of the door switch in the door' s female striker latch.
Let us know the results. It's a common problem and we can help. If I'm wrong, we'll try another test.
John
Old Jan 8, 2018 | 02:43 AM
Losing window limit switch settings for the auto drop feature is often the first sign of a failing battery.
With modern Jaguars, always check and eliminate battery condition/charge first as a possible cause before looking for failed components or harness issues.
Old Jan 8, 2018 | 04:42 AM
jelu02's Avatar
Smile Battery indeed!
Hi,
I had the same problem with my XK8 -04 sedan.
Battery was only half charged due to me only driving 10 km to work.
After being fully charged, both windows lower slightly when doors are opened and raise fully when doors are closed.
Remember to reset the bottom-top positions for the windows by lowering, hold the button and wait for the click-sound.
Do the same procedure when raising the window.
Old Jan 8, 2018 | 08:20 AM
Scottsgreenjag's Avatar
From: Somewhere south of Grand Rapids, Michigan, USA
My 98 did the same thing about a year ago, the factory window reset as mentioned above cured mine.
Old Mar 13, 2019 | 06:11 PM
Muncie6spd's Avatar
My 02 XK8 had this same problem, I reset the windows with this procedure and solved my problem!
THANKS!!
99xk8guy
Sep 29, 2025 10:51 PM
chuckh007
Oct 4, 2014 06:08 PM
oldtrojanrunner
Mar 25, 2014 08:35 PM
david i
Apr 2, 2012 04:11 AM
