New XK8 owner
Old Apr 17, 2026 | 01:00 PM
bturner425's Avatar
Default New XK8 owner
My name is Brian Turner and I live in Grafton, Ohio. I am looking at buying a 2000 XK8 with 82000 miles. The car has the V8. It lived its life in Florida with two owners. I did a CARFAX on it and it looks like it had typical Jaguar issues, brake light switch, oil pan gasket replaced, valve cover gaskets replaced, radiator replaced, a/c compressor replaced. I will only drive it in the summer as a fun car, daily driver. I’ve always heard that Jaguars have their problems so I hope I’m making the right decision here. I have always wanted a Jaguar. Thanks for meme troll here and I will let you know if and when I take possession of it.
Old Apr 17, 2026 | 05:26 PM
Daf11e's Avatar
Welcome aboard Brian.
Old Apr 18, 2026 | 07:09 AM
Welcome to the Forums.
Old Apr 18, 2026 | 08:32 AM
Welcome to Jaguar Forums Brian,
Head on over to the X100 section for all the info you need. https://www.jaguarforums.com/forum/xk8-xkr-x100-17/
Old Apr 19, 2026 | 08:55 AM
Hello,
Old Apr 19, 2026 | 10:06 AM
Old Apr 21, 2026 | 05:08 PM
bturner425's Avatar
Default My New Jaguar
So, I went and bought a 2001 XK 8.
Old Apr 21, 2026 | 07:17 PM
very nice!!! Front end looks a little low - check the upper shock mounts for signs of disintegration and if they are bad, reach out to @cjd777 or @baxtor as they have developed a very robust and cost effective replacement. It is a fairly simple diy - have done the job many times on my 2000 XK8 until I switched to their solution
Old Apr 22, 2026 | 08:24 AM
bturner425's Avatar
They were replace in 2023 with about 94,000 miles. It now has 103,000.
Old Apr 22, 2026 | 08:45 AM
wymjym's Avatar
One would assume that information precludes the need to replace them but I' sorry to tell you. It doesn't. Check them out and make an informed decision.
wj
Old Apr 22, 2026 | 08:47 AM
bturner425's Avatar
Thanks. Will do.
Old Apr 22, 2026 | 12:12 PM
bturner425's Avatar
How do these look?
How do these look?
Old Apr 22, 2026 | 12:16 PM
wymjym's Avatar
good, but your front end does look low! Maybe your rear end is a bit too high, something is off a little bit. BTW this subject will get better response in the xk100 forum.
wj
Old May 14, 2026 | 09:45 AM
bturner425's Avatar
Records show these are URO brand strut dampers. I understand these don’t last very long, so I guess I’ll be replacing them soon.
Old May 14, 2026 | 10:57 AM
cjd777's Avatar
Brian, you can get a bit more information as to the condition of things by taking a few measurements.
Each measurement is taken from the center of the wheel, right in the middle of the emblem to the curve at the top of the fender ARCH. The stock measurement runs from 15-7/8 to 15 -1/8 on front and back, higher might be a sign of new springs and shocks for a short period of time.
If down below 15, mounts will help but an indication your springs are getting weak.
Nice car, have fun with it.
With any luck at all, what you have on there will get you into the winter months when you indicate you will put the car up.
At that time, take some measurements and give me a shout and let's see what you have and which direction you need to go.
Old May 14, 2026 | 05:01 PM
sanchius's Avatar
JAGUAR - Turning owners into mechanics since 1935.
Old May 15, 2026 | 07:30 AM
wymjym's Avatar
So true and funny!
wj
Old May 15, 2026 | 07:42 AM
LMG's Avatar
LMG
Old May 15, 2026 | 08:34 AM
Jon89's Avatar
A production run of that shirt would sell out on Day One....
Edward_Woodward
Feb 8, 2023 07:18 PM
Burdedw
Jun 21, 2013 04:19 AM
Jeff.Jag
Feb 27, 2013 02:12 AM
15FTypeR
Mar 21, 2010 01:33 AM
K.Westra
Sights N Sounds
Jun 24, 2009 08:01 AM
