Hi all, I’m a GM master tech and enjoying more than I can chew learning about this jag and need a world of help, lol. HISTORY: It’s a U.S. car, left hand drive. Car is new to us, purchased as is so I know nothing about it, I have the wiring, diagnostic/test and workshop manuals. None of which has any diagnostic flow charts to provide sensible help. COMPLAINT: 1) engine will not crank. OBSERVATION, starter motor works fine, with relay removed and jumped, starter draw only 53 Amps. Relay is not not getting triggered. Key doesn’t have a transmitter device so I don’t think it has a decoder. Ideas?
COMPLAINT: top is dead. OBSERVATION: key in door turning left, nothing. Key on, moving toggle switch, I can hear clicking in the trunk. When we first got it, it was up. Followed this forum and got it down.
OTHER DETAILS: key on, cluster check reads 1) electrical fault 2) transmission fault 3) low outside temp 4) suspension fault 5) engine fault (currently valve covers, coils and MAF sensor is off though) 6) incorrect part fitted.
finally, if successful I attached a pic of a connector in the truck in front of the battery. What is supposed to be connected to it? Pencil tip pointing to connector in question
The CAN bus (Controller Area Network) is what links the ECM, Gear Selelector Illum module TCM, ABS, INSTPK as a network.
lol, thank you. Serial data bus over here. The fun part of this car is 5 minutes finding something in the manuals then 10 more minutes on the web translating to American English.
Steep learning curve so I appreciate the patience.
