Noise coming from driver side dash
I am getting what sounds like a metal on metal noise from my driver side dash. It sometimes manifests itself as a bird like song. My mechanic advised there are bars installed to help with rattle in the convertables and that may be the problem. Any one have any ideas?
Item 1 in the first diagram is accessible from the engine compartment (there's two of these braces).
The dash braces are accessed from inside the vehicle and dismantling is required to get to them.
Reach over the dash and press on the defroster vents next time you hear the noise. They are a common source of strange sounds. If that is the problem, search the forum for the fix.
Check your top shock mounts - I had a similar noise on my car and that's what it turned out to be - sounds just like a birdsong. If that is the problem there's a couple of threads on here as to how to change them.
I am curious to see if you find a solution to this as I havethe same issue. At low speeds you can hear a chirping sound believe it or not.Two years ago I did fix my vents and that issue was resolved. Last month I took the dash surround off andpoked around in behind the steering wheel but could not find anything loose orrubbing together. My next project will be to remove the wipers and check theengine brace.
Yes you are right. I tightened those as well. That was an easy check.Thanks.
Anyone know if it would be easier to just disconnect the braces in theengine compartment and seeing if there is any movement prior to going through thehassle of removing the wipers and grille?
+1 on the front upper shock bushings. The noise was transmitted through the brace running from the shock turret to the dash. You may also notice that the shock mount is off-center in the turret. Replacing the bushings fixed it.
Sam
Sam
xjrjag
Nov 27, 2025 09:16 AM
BrentGardner
29
Dec 16, 2024 12:13 AM
