Non-working 9005 HID conversion.
Old Jan 20, 2020 | 01:41 PM
wymjym's Avatar
Default Non-working 9005 HID conversion.
Help!
2005 xk8
I pulled out my LED Hi Beams, as they didn’t have any depth of light and installed a set of HID 9005s with high hopes.
I had been so pleased with my earlier installation of HID 9001 low beams that I was hoping for an improvement over the stock bulbs. Well, I’m baffled…neither hi beam functions, they both have +12v going to the ballasts. The odds of both units being faulty I would image is pretty rare but I do not see where I have gone wrong.
The only question I keep having is that there was an 8” length of cable with a male and female connector on each end which was plugged into the ballasts. I removed them as they were inline connections without any ICs and I thought of them as simple input extensions, maybe I was wrong. Since I mounted everything inside the light housings I didn’t have a lot of extra room for these extensions and I don’t really want to pull it all apart again unless it is necessary for replacement of a component.
Any thoughts as to what I might have done wrong?
To recap:
Fuses good
Power measured at input to ballasts
None functioning lights (both)
wj
Old Jan 20, 2020 | 06:25 PM
DavidYau's Avatar
Default Do you have the igniter?
Wymjym,
I haven’t done the HID conversion on my 99 Jag, but from what I understand HID bulbs need a separate igniter to up the voltage.
Did that come in the kit?
Old Jan 21, 2020 | 03:15 AM
dibbit's Avatar
Originally Posted by DavidYau
Wymjym,
That is the ballast he talks about.
I would double check that the positive and negative are the right way round to the ballast - it won't work otherwise.
Old Jan 21, 2020 | 04:11 AM
frankc's Avatar
Hi , been there done that. :-D including the not working bit.
If I remember right it was down to the wiring. Will look up my posting on the subject for you, brb.
Old Jan 21, 2020 | 04:15 AM
frankc's Avatar
Here you go. Read 5A and you will, or rather should, see the solution. https://www.jaguarforum.com/showthre...=1#post1025402
Dont forget to let us know if it works wont you??
Thanks!
Old Jan 21, 2020 | 01:16 PM
wymjym's Avatar
Thanks!
Thanks everyone.
FranckC you were on the money. I reversed the plugs and everything works.
For those that wonder how someone can ‘plug it in backwards’;
the ballast has a female receptacle with a locking tang, the jaguar plug has the counterpart on its plug…so I thought the normal approach would suffice, it didn’t. I assume that when these are manufactured this small point isn’t of much concern. Never the less, they now function.
I’ll report back next week after I get a chance to try them out at night and make some adjustments. I can tell from the pattern on my wall they are a major improvement compared to both the original bulbs and the LED conversion I did earlier.
I guess the LEDs will finally reside in my fog light assemblies.
wj
Old Jan 21, 2020 | 04:20 PM
frankc's Avatar
Great stuff. I can imagine how it felt when they did light up.
People have asked me why did I not install LED lights and it was because of reports from people like yourself.
The HID lights make a massive difference. Its one mod I highly recommend.
Thanks for letting me know it worked. I do a lot of writing about our XK100 cars and its always good to get feedback. Thanks again for letting me know it worked!
Chuck Schexnayder
Jul 9, 2014 08:25 AM
luc
Nov 16, 2012 10:11 PM
roblox84
Jan 2, 2012 08:38 PM
Rich W
Aug 1, 2009 09:11 AM
alarsen77
Sep 28, 2008 11:48 AM
