Occasional engine failsafe mode
Old Oct 3, 2023 | 07:15 PM
Sparky565706's Avatar
Default Occasional engine failsafe mode
I just bought a 2002 jaguar xk8 and sometimes when I get in it will not turn over or start and I'll get a few messages saying: engine failsafe mode, gearbox fault, traction control fault, and asc fault. Sometimes it will happen while I'm driving. When this happens I can wait a couple minutes and it will crank right up. The engine does not miss but is a bit sluggish when it does run. The transmission shifts a little rough sometimes. I just put a battery in it, so it shouldn't be that. The tps sensor looks new but I did not replace it. There is a code for an O2 sensor on bank 2 (p1647). I've got codes for the input turbine shaft (p0715) and CAN tcm to ecm malfunction (p1797). This is all the info I have right now
Old Oct 4, 2023 | 01:52 AM
Pistnbroke's Avatar
I dont care if its a new battery ..charge it overnight ..clear the codes and start again
Old Oct 5, 2023 | 05:14 PM
[QUOTE=Pistnbroke;2683947]I dont care if its a new battery ..charge it overnight ..clear the codes and start again]. I tested the battery and it came back perfect, 100% charge. I also cleared the codes and it did fine for a little bit but It went into reduced power mode while I was driving but went away after about a minute
Old Oct 6, 2023 | 01:50 AM
Pistnbroke's Avatar
The only reduced performance I have had is when it has got water into one of the spark plug holes via poor seals on the coil covers.
Old Oct 6, 2023 | 01:53 AM
i just replaced the valve cover gaskets, plug well gaskets, plugs, and coils last week. They are all holding fine
Old Oct 6, 2023 | 08:22 AM
JagV8's Avatar
Did you fix the bad O2 sensor?
Old Oct 6, 2023 | 09:25 AM
I have the new sensor, I'm just trying to get a socket to get it out.
Quinn Thurman
Sep 30, 2020 10:26 PM
Terrance39
May 4, 2019 07:32 PM
busaboy1969
General Tech Help
Sep 1, 2014 12:29 AM
smtguy
May 14, 2013 08:12 AM
kdross
Nov 2, 2010 02:32 PM
