Odd overheating problems, please help!
Old May 19, 2010 | 04:45 PM
Brian2000XKR's Avatar
Hi,
I have had that very same sporadic problem a few times over about five years. Every time that it happened, it was easily cleared up and was really not a real issue.
Try this: Turn your key on and then run the gear shift knob through the gears. You may have to start the car in Neutral.
Let us know if that fixes the problem for you.
Good luck!
Brian
Old May 19, 2010 | 05:37 PM
H20boy's Avatar
My jag service adviser hinted to me once that the pans can leak. it could have lost a little bit over time, now its low. A fluid, filter, and gasket swap could be just what the doctor ordered.
Lots of threads on transmission fluid changes in this forum and the xJ8s as well (same tranny), I'd do a search to be well versed in the process and options on fluid substitutes.
best of luck!
Old May 19, 2010 | 06:05 PM
In my case, it was a totally bogus message, as I got it after the car sat overnight. It really had nothing to do with High Transmission Temperature. I was sure happy that it was really nothing at all.................
Brian
Scarecrow
Mar 28, 2016 03:17 AM
Raul Lara
Sep 14, 2015 07:31 PM
alpecsa
Sep 7, 2015 11:55 AM
carelm
Sep 5, 2015 01:13 AM
Raul Lara
Sep 2, 2015 05:23 PM
