Oh my. This hose is bulging.
Old Feb 18, 2026 | 07:10 PM
2500DollarXKR's Avatar
Default Oh my. This hose is bulging.
which one is this and how difficult to replace? I've looked through the diagrams and parts list but wanted to get some insight from the community.
Old Feb 18, 2026 | 09:12 PM
cjd777's Avatar
Time to get a new one.
Your choice, stock or cut it in half to remove and take it to the store and get a replacement the same size, silicone would be my choice.
Old Feb 18, 2026 | 10:47 PM
Dr. D's Avatar
The hose is listed as:
Housing To Coolant Inlet Hose AJ811638 (supercharged)
As for difficulty, the closeness between these two metal hose fittings is about 1.5" (inner radius) and 3" (outer radius). I do not know if anyone has been sucessful in finagling the new hose back in by just undoing its clamps and disregarding this following suggestion:
I suggest undoing the aluminum outlet pipe /thermostat housing by removing 4 screws (2 into each cylinder head). Consequently, when separated, the (2) Water Outlet Seals C2C11477 (on the housing for each cylinder head) will probably be age/heat flattened or worse and need replacing.
Old Feb 18, 2026 | 10:53 PM
pcolapacker's Avatar
Thermostat housing to coolant inlet. I changed mine a couple months ago. Helps if have clamp pliers. The lower opening was “welded” to the metal. Cut in half and slipped an awl between rubber and metal to release.
Doug5.0
Apr 30, 2025 04:22 PM
Gates02
Apr 5, 2024 11:10 AM
Stosh1017
Nov 1, 2023 03:05 PM
wsn03
Jan 30, 2022 02:56 AM
LT1 jaguar
May 21, 2021 04:26 AM
