Oil Change on the beast-A work out with jack
Old Aug 4, 2011 | 08:48 AM
Mountaincat's Avatar
Default Oil Change on the beast-A work out with jack
Just did my first oil change on the XKR---what a work out with the hydraulic jack! I'm curious what others do when changing their own oil.
1. Do you change the pan (sump) plug on every oil change?
2. Do you jack up the rear of the car to get all the oil out of the pan?
One interesting note is that you need a large oil collection bucket to hold 8+ quarts of oil. I was used to doing oil changes on cars holding around 5 qts. I was prepared as I had a larger bucket, but when I jacked the rear up I almost crushed the bucket. Not sure I need to jack the rear next time.
Old Aug 4, 2011 | 09:14 AM
pophen's Avatar
Mountain cat, change oil and filter every 5K in my '98 XK8. Just lift the car enough to get the jack stands, set on the second notch, under the car. Have never changed the drained plug and it's never leaked. Thanks to NutriSystems I can get this 64 year old body under the car without too much trouble sliding on a piece of cardboard box. I get 5+ qts. out of the crankcase into my oil change pan which I drain into the 5 qt container from last change. The pan goes back under for what ever comes out of the filter. I buy 15 qts at a time and split it with my '07 X-type. Each car takes 7 qts. with the remaining for top offs if needed. Jack
Old Aug 4, 2011 | 09:29 AM
test point's Avatar
I changed mine with the car on the ground with a low catch container. You really do not have to get under the car for either the pan plug or filter.
FabCat
Canada
Aug 20, 2023 10:11 AM
JaguarXKR
Sep 6, 2015 11:47 AM
niner nellie
Sep 1, 2015 10:53 PM
DeaconHull
Aug 31, 2015 10:09 PM
TC Johnson
Aug 29, 2015 08:55 PM
