Oil cooler pipes 2001 xkr
Old May 31, 2020 | 01:20 AM
brinny's Avatar
Default Oil cooler pipes 2001 xkr
Do the oil cooler pipes present any known problems? Also are they difficult to change. Thanks for your help
Old May 31, 2020 | 03:33 AM
mhminnich's Avatar
Yes to both! They are engine killers if they burst and are also easy to change.
Old May 31, 2020 | 01:55 PM
fmertz's Avatar
To be clear, the _engine_ oil coolers lines are (4) separate sections of "hydraulic" Aluminum/rubber that have a ball park lifespan of 10 years. They are somewhat pricey ($400?) but pretty straightforward to replace. One or more seeping joints is red alert as they ALL see max oil pressure, so all (4) need to be replaced at once. If a joint bursts, all the oil is pumped out of the engine in seconds, and the ignition needs to be shut down FAST.
The _transmission_ oil coolers are a combination of hard metal pipes with flex ends to the cold radiator end tank. Those tend to last but are a bear to replace as they snake around a bit with multiple intermediary hold points. I have no direct experience with that job.
Best of luck, keep us posted.
Daim
Jun 3, 2016 12:40 PM
raphell
Sep 10, 2012 07:03 AM
wallacesims
Aug 14, 2012 12:35 PM
jagxkrtoofast
May 19, 2012 09:22 AM
Grendel
Sep 29, 2010 04:00 PM
