Oil Drain Plug Gasket
Old Apr 10, 2011 | 12:53 PM
JagYour's Avatar
Default Oil Drain Plug Gasket
Trying to change my oil today and when I replaced the oil drain plug gasket it does not seem to fit properly. When I removed the plug there is a rubber seal that fits into a groove. I ordered a new oil drain plug gasket but it does not fit into the groove like the old rubber seal did. The new one (part # NCE 1850AB) is brass with a rubber center. It will not fit into the groove so I am reluctant to put it back on the car in case I do not get a good seal. Does anyone know if this gasket can be used at all or should I just order a brand new drain plug which includes a new rubber seal?
Old Apr 10, 2011 | 01:07 PM
JagXK82001's Avatar
Dealer cost for a new drain plug will probably be $300 plus. And the o-ring gasket another $10 or so.
Don't know why you could not just use a standard O-ring in the correct size from a hardware store.
Old Apr 10, 2011 | 04:18 PM
WhiteXKR's Avatar
$300??? It lists for under $8.00.
Old Apr 10, 2011 | 07:24 PM
cheaperts's Avatar
Bless you, the 300.00 comment had me redy to throw up!
Old Apr 10, 2011 | 07:25 PM
cpm53's Avatar
I bought a new drain plug at my dealer last year and I think it was ~$12.00. The O ring is built into the plug on an `03 XKR and it looks just like the drain plug on my `99 Ford Expedition. I`ve changed oil on my Expedition 50 times since new and I`ve never replaced the plug. I bought a new plug for the Jag because I wanted to pamper the kitty!!
Old Apr 10, 2011 | 07:35 PM
Reverend Sam's Avatar
I'm pretty sure you can use the drain plug from a Lincoln LS.
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
cissdm
May 3, 2016 06:02 AM
Scarecrow
Mar 28, 2016 03:17 AM
AL NZ
Sep 4, 2015 08:39 PM
