oil pressure switch that went bad
Old Aug 14, 2013 | 08:51 PM
nine7xk8's Avatar
Default oil pressure switch that went bad
My oil pressure light was going to red and back to normal. This is what I found
Last edited by GGG; Aug 15, 2013 at 02:51 AM. Reason: edit typo in thread title so it appears in searches
Old Aug 14, 2013 | 09:03 PM
WhiteXKR's Avatar
Is it only during idling or when you are driving also?
Old Aug 15, 2013 | 12:41 AM
nine7xk8's Avatar
what I found was this white xkr . a broken sending unit
Old Aug 15, 2013 | 12:43 AM
nine7xk8's Avatar
that is to tell me that when people get this type of problem, its most likely this pressure switch thats causing it. Even if the switch dont look broken the way mine did, I could imagine that they go bad
Old Aug 15, 2013 | 12:51 AM
nine7xk8's Avatar
P.s. People that dont have a rag top xk8 wish they did. hardtops are not that attractive. and why does it seem like the more you work on these cars the more you fall inlove with them
Old Aug 15, 2013 | 02:54 AM
If I lived in LA, I'd probably agree about the Convertible. If you lived in the UK, you'd probably prefer the Coupe.
Old Aug 15, 2013 | 06:18 AM
WhiteXKR's Avatar
Besides the switch, another common cause is the oil sump screen getting clogged with plastic bits from broken tensioners and chain guides.
Old Aug 15, 2013 | 10:01 AM
Paul Pavlik's Avatar
Gosh, I thought that my car was Beautiful. Glad that you clarified that.
Old Aug 15, 2013 | 01:56 PM
H20boy's Avatar
...or remember the block shavings I found?!?
Old Aug 15, 2013 | 03:22 PM
Mr. Feathers's Avatar
I second the oil switch thing. I actually paid $150 for the dealer's second opinion - which was A) bad switch, or b) worn rod bearings. Bought a switch for $18 from O'Reillys and replaced it myself & that fixed the problem instantly Now I wish I hadn't wasted money at the dealer...
Old Aug 15, 2013 | 04:02 PM
SteveJacks's Avatar
I want one of each, both are beautiful.
Old Aug 15, 2013 | 04:06 PM
WhiteXKR's Avatar
The switches do go bad, but an oil sump clogged with plastic bits is also a reality on these engines and an inspection can give you an idea as to the condition of the plastic timing components.
toronadomike
Jan 22, 2026 10:13 PM
bamforp
Aug 14, 2024 05:36 PM
jaguarbill
Sep 5, 2015 11:43 AM
Dymaxxion
Sep 4, 2015 02:40 PM
laserguy
Sep 3, 2015 02:02 PM
