Oil in TB
Old Mar 19, 2013 | 12:46 PM
randyb's Avatar
Default Oil in TB
When I look in the PCV pipe opening in the PS valve cover, I see a metal plate underneath, should I not be seeing some kind of baffling?
Old Mar 20, 2013 | 11:59 AM
The Coupe's Avatar
Randy,
If you see the metal plate, you're good. Your oil separator is in place. The metal mesh that's also part of the oil separator can't be seen through the breather hole.
Check this thread for some photos.
Oil in the Airbox - Might be an Easier Fix Than You Think - FAQ
Old Mar 20, 2013 | 01:28 PM
randyb's Avatar
Thanks, now I am worrying again.
MrWhite
19
Jun 14, 2022 07:49 PM
Dave1109971
Dec 15, 2015 06:16 PM
3jagfamily
Oct 1, 2015 01:49 AM
Woznaldo
Sep 26, 2015 11:02 AM
ahunt4
Sep 25, 2015 03:43 AM
