Oxidising door seals
Old Feb 8, 2021 | 02:55 AM
DougXK8's Avatar
Default Oxidising door seals
As I am sure many forum members have experienced the original rubber covered aluminium seal being prone to aluminium oxidising and causing the rubber to bubble up. I have seen a seller on e-bay selling replacement rubber seals for both drivers & passenger doors and rear window rubbers. Has anyone purchased these items recently and how did they find them?
Front. eBay item number:174541351122
Rear. eBay item number:174577122840
I would be interested to know how easy it is to remove the existing seals and how easy it is to fit the new ones.
Old Feb 8, 2021 | 03:31 AM
The waist rails are held on with spring clips. No screws involved and pulling upwards frees them but it may take some assistance with a thin wooden or plastic spatula at the bottom edge to get them started. Work gradually along the length to avoid distortion. Covering the paintwork at the top of the door with masking tape is a good precaution to avoid scratching.
It's surprising how apparently terminal corrosion can be removed and the waist rails successfully refinished. See this thread:
https://www.jaguarforums.com/forum/x...q-55561/page2/
Unfortunately Keith's photos in the first post disappeared when he moved his online storage but there are plenty of others in the thread to show removal and refurbishment.
Jaguar resolved the waist rail corrosion issue on the later XK by using stainless steel but unfortunately never changed the design of the XK8.
Old Feb 8, 2021 | 04:57 AM
bladerunner919's Avatar
Looks very much like this stuff which is £3.20 a meter! https://sealextrusions.com/collectio...29375747522647
Old Feb 10, 2021 | 04:34 AM
DougXK8's Avatar
Thanks both. Really helpful.
Old Feb 10, 2021 | 06:01 AM
Please let us know which solution you finally choose. This is a regular issue and all options are useful.
Old May 24, 2021 | 09:11 PM
srpope80's Avatar
Definitely following this thread. Might try to paint mine on the Craigslist Cat, but wish a direct replacement was available.
Old Jun 9, 2021 | 05:14 AM
sossybaby's Avatar
Didn't someone on xk8 Facebook mention the Mini R53 had a near identical door seal.
I ordered a pair from the breakers.
Keyed the chrome strip with wire wool, then two coats of etch primer/dorchester grey/lacquer.
Are they an exact match, no but a layman wouldn't notice the difference.
And hey, £25 delivered. can't complain.
Old Jun 9, 2021 | 06:15 AM
Jon89's Avatar
Well done....
redtriangle
Mar 31, 2023 01:53 PM
wombat
Apr 4, 2020 11:57 AM
Panelhead
Oct 3, 2019 06:59 AM
Devendra Singh
Mark V - X 420G
Feb 3, 2016 04:38 PM
Katoh
Jun 27, 2013 03:03 PM
