passenger seat controls defect
Old Nov 19, 2008 | 11:34 AM
Brutal's Avatar
Default RE: passenger seat controls defect
USUALLY A MODULE WITH NO OPERATION AND POWER, BUT THEN YOU CAN ALWAYS TAKE OUT THE MODULE AND SWITCH PACK ON THE DRIVERS SEAT AND MOVE THEM OVER TO CHECK FOR WHAT IS THE PROBLEM. JUST DONT BREAK THE SWITCHPACK TAKING IT OUT, AND YES THE MODULE WILL OPERATE OK, BUT THE SWITCH PACK OPERATES REVERSE FUNCTIONS. BUT YOULL GET THE IDEA.
Old Nov 19, 2008 | 11:36 AM
whiteSTR's Avatar
I have the same problem, but only with certain functions on the seat.. Headrest adjust, lumbar, and the seat heater.. Its only my passenger seat as well. Does the seat heater on yours work because we may have the same problem?
Old Nov 19, 2008 | 03:25 PM
stevef's Avatar
I had the same problem on my 06 xkr nothing was working on the drivers seat, I found that the connector from the seat to the car was unplugged, there was a white connectorunder the seat that came loose, refastened it and all was fine, check to see if everything is connected under the seat.[/align]
Old Nov 19, 2008 | 04:16 PM
test point's Avatar
As with any of the many 'modules' within the electrical system be sure to disconnect the battery cable before connecting or disconnecting the unit. The seat modules are a common failure item. If defective, they can usually be found on eBay or one of the several recycling yards web sites for $100 or less. The same unit for a Ford vehicle is about $20. If only we could find a conversion table.
There are a couple of threads on repairing the unit, both relays and connectors. Search this and other forums.
Old Dec 17, 2008 | 05:21 AM
GreenJewel's Avatar
Should the passengers seat go up and down as well as fore and aft on a 2000 XK8? The passenger's seat in my 2000 goes fore and aft and the back tilts fore and aft. No seat up and down.
Old Dec 17, 2008 | 08:28 AM
Brutal's Avatar
ORIGINAL: GreenJewel
NO YOU DONT HAVE UP/DOWN ON PASS SEAT
Old Dec 18, 2008 | 12:07 PM
GreenJewel's Avatar
ORIGINAL: BRUTAL
That's what I figured but one can dream.[sm=boosign.gif]
Thanks for the reply. [sm=icon_cheers.gif]
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
JeffinSwitz
Sep 16, 2015 01:44 PM
avern1
Sep 8, 2015 06:25 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
