Passenger seat module
Old Nov 2, 2013 | 04:47 PM
David Lawson's Avatar
Default Passenger seat module
I took my seat out and had all the motors checked by a tech and all good working order but the seat module is fried with burnt areas and need a plug and play module if possible and asap and maybe you folks know of module forsale and the module box say made in Spain by Ford LJE2160AB/XXX I welcome any input to resolve this seat issue
Old Nov 2, 2013 | 07:26 PM
The one from my 2005 XK8 has exactly the same numbers:
You'll see the lid is marked 'THIS PART IS PROGRAMMABLE'.
Any equivalent module can be reprogrammed to your vehicle by the dealer but if you want to avoid having to have the replacement reprogrammed, make sure you get one from a vehicle which has the same options fitted e.g. 12 way Seat, Powerfold Mirrors etc.
Attached Thumbnails Passenger seat module-11a-passenger-seat-module-cover-removed.jpg
Old Nov 2, 2013 | 08:01 PM
test point's Avatar
Because of the memory function associated with the driver seat and its interface with other modules it is programmed to match the vehicle. I do not think that the passenger seat module is really programmed. I have had good plug-n-play results with two passenger seat modules without programming.
Wish someone with other than opinions would chime in on this issue so that we could have a definitive answer.
Old Nov 20, 2013 | 09:19 AM
johnnie ryall's Avatar
The seat module has to be programmed while plugged into the driver's side. The module 'knows' what side its in by the location of the ground pin in the connector. And this programming must be done in an 03-06 car. If you have a 2002, and get a new seat module, you have to track down a newer model to plug the module into and program it, then plug into the earlier car. If you buy a used one from a like equipped parts car, you wont have to program.
Old Nov 20, 2013 | 04:41 PM
Gus's Avatar
Gus
Why not see if it can be rebuilt and a fraction of replacement?
Try ASI Link Welcome To Auto ECU Inc.
Old Nov 22, 2013 | 10:50 AM
Default Update to buy a new seat module cost from Jag dealer
Just a quick update for a new passenger seat module from the dealer at Scott Jaguar in Charlotte,NC. Seat module is $1050.00 + programming + installation so I bowed out gracefully on that quick fix just for a module for a seat. I just used my driver side module and set the passenger seat to comfy position and in process of waiting to hear back from auto ecu for a rebuild of the seat module and or find a like module used for my car.
Old Dec 25, 2013 | 05:59 PM
2ndxk8's Avatar
David,
I'm also in the Charlotte area and in need of a drivers seat module for an '06 XK8.
Have you had any luck?
I will post if I find a cheaper solution.
2X
Old Dec 25, 2013 | 06:30 PM
test point's Avatar
Just had mine 'repaired' for $50 plus $7 shipping.
https://www.jaguarforums.com/forum/x...08/#post827086
JeffinSwitz
Sep 16, 2015 01:44 PM
multijag
Sep 14, 2015 04:54 PM
diablomkii
Sep 14, 2015 02:37 PM
avern1
Sep 8, 2015 06:25 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
