passenger seat stuck
Old Dec 11, 2018 | 02:34 PM
attaboy's Avatar
Default passenger seat stuck
03 xk8 passenger seat stuck in forward position
Old Dec 11, 2018 | 02:56 PM
larueb's Avatar
When you say stuck, do you mean the power seat control does not move the seat?
Two things to look at
1- the switch on the side of the seat;
2- module that controls the movement
does the seat move at all with other controls?
Old Dec 12, 2018 | 07:19 AM
attaboy's Avatar
I guess I should have been more specific after finding another thread dealing with seat-back positioning. The passenger seat back is in the forward .. towards the dash position, and while the release lever does move with normal effort as it should, the seat back will not release to return to the normal reclined position. None of the motorized functions work, but I expect that they are disabled with the seat-back in the dash-forward position. I would think that this is purely a mechanical latch function, but perhaps there is more going on there. I am lacking insight into any fault analysis, as I was not the person who put the seat into the dash forward position .. it was being "pre-detailed" as it were. This has never happened before, with either seat.
Old Dec 12, 2018 | 09:14 AM
larueb's Avatar
Sounds as it the seat might be "jammed". When the seat is all the way forward, I believe the mechanical release will not work.
Start with the easy solution. Check the fuses that support the passenger seat, should be 2 if I recall correctly. This will be in the chart in your owners manual.
Good luck!
wforslund3
Nov 24, 2018 06:19 PM
Matt Cox
Nov 20, 2018 01:21 PM
Christopher
Nov 17, 2018 08:00 AM
Duchess
Nov 15, 2018 09:13 AM
ericjansen
Nov 13, 2018 07:31 AM
