Pcv?
Old Feb 24, 2011 | 08:52 PM
Spurlee's Avatar
Default Pcv?
Is there a PVC valve lurking somewhere on my 4.0?
If not, hows that happen?
Thanks!
Old Feb 24, 2011 | 09:18 PM
WhiteXKR's Avatar
The Jag V8 uses a calibrated orifice in the valve cover called the 'part load breather' for closed crankcase ventalation...no PCV valve.
Old Feb 26, 2011 | 01:34 PM
Martin's Avatar
Does it ever need to replaced or cleaned. Where is it? Spurlee asked the frist question, I'll ask the second. We are "tag teaming" you. Thanks!
Old Feb 26, 2011 | 01:53 PM
WhiteXKR's Avatar
Sure does...every 10,000 miles is recommended for a cleaning. Not a hard job.
Old Feb 26, 2011 | 02:37 PM
RCSign's Avatar
Always learning something new on this forum.
Doug
2001 XKR Silverstone
Old Feb 26, 2011 | 05:30 PM
Spurlee's Avatar
Thanks!
That is the oddest set of instructions: Check the action of the full load breather with a piece of paper and regardless of what happens, clean the part load breather anyway.
Mine was clean.
Old Mar 5, 2011 | 05:36 PM
1999JagXJ8-Butler's Avatar
Default Full load breather
On the right front valve cover. No pvc, goes directly to air filter feed.
my problem is the orafice on the valve cover is broken, piece missing on largest opening of it. the host cannot clamp on to it, so i get oil leaking when pushing the engine.
without changing the valve cover, is there anything someone has done to rig up a rubber hose or pvc grommet?
thanks
Old Mar 5, 2011 | 05:47 PM
WhiteXKR's Avatar
Here is a used valve cover for $30 bucks. OK, $50 with shipping.
http://cgi.ebay.com/ebaymotors/jagua...Q5fAccessories
Old Mar 6, 2011 | 10:03 AM
Thanks WhiteXKR. Yes i was looking. my engine is A27 and has the selenoids in the front on top of cover. I was reading another thread that 1999 had 2 engines depending on build date, and those valve covers are different in regard to the selenoids
enjoy spring
Old Mar 7, 2011 | 02:56 PM
govatos's Avatar
The pdf shows the location on the XK8. Where is it on the R?
Old Mar 7, 2011 | 03:02 PM
WhiteXKR's Avatar
It is the same. On the R, there is just no engine cover to remove. This was written for the 4.0. Maybe someone else can chime in on the breather differences on the 4.2 that you have.
silkcat
Jan 18, 2025 04:29 AM
philwarner
Dec 6, 2021 07:13 AM
Gibbo205
May 28, 2014 04:16 PM
bulkmail07
Jan 31, 2012 04:31 AM
