plastic or metal impeller wp?
Old Mar 11, 2015 | 01:42 PM
cruisin's Avatar
Default plastic or metal impeller wp?
What's the current thinking on which is better. metal impeller or the white plastic. seems obvious, but I've seen (old) reports of the metal ones failing also, and they recommended using the white plastic instead.
Russ
Old Mar 11, 2015 | 01:47 PM
Brutal's Avatar
All parts fail but stay away from stamped metal impellers. Theyre a straight blade, not curved or precisly fit to housing like the plastic and have terrible coolant flow. Beside the plastic impeller issue was a later 90's and early 2000's issue on original fit pumps. Its no longer a issue except the new 5.0litre
Old Mar 11, 2015 | 01:51 PM
brgjag's Avatar
I bought metal for my 03, didn't like the fit and finish, went with orig type pump!
Old Mar 17, 2015 | 10:06 AM
P700Dee's Avatar
Get the current Jaguar spec (plastic) not a metal one
Old Mar 17, 2015 | 10:36 AM
+1 on going for plastic. Several reports on the forum of issues with the metal ones.
Don't get too concerned with the white or orange colour of the plastic impeller on current replacement water pumps.
The original problem impellers were white and Jaguar upgraded OE were then coloured orange. However, recently a number of aftermarket replacements have gone back to using white again. A strange decision but it is 17 years after the problem was resolved!
Old Mar 17, 2015 | 10:44 AM
RJ237's Avatar
A white impeller is not necessarily the same plastic as the early model.
Old Mar 17, 2015 | 11:15 AM
brgjag's Avatar
I would think any old orig EOM like plastic impeller is fine. If you keep the rad fluid changed as needed I don't see why the need to go metal. I think most folsk get close to 100k out the orig units, I got 97k out of mine and with WP being so cheap and a easy repair i would not worry about metal if you have your car long enough to have to do another WP in another 80k+ miles.
Old Mar 17, 2015 | 02:23 PM
RJ237's Avatar
The earliest V8's had an impeller that becomes brittle and crumbles. Most of these have been replaced, but there may be a few low mileage early builds still at risk.
MrWhite
33
Oct 22, 2015 10:29 AM
adam699
Oct 13, 2015 05:53 PM
Delta66
Oct 4, 2015 05:40 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
