Please confirm brake pedal microswitch
Old Aug 21, 2024 | 05:10 PM
XK8FAN's Avatar
Default Please confirm brake pedal microswitch
Brake lights stuck on unless I wiggle the pedal, so I assume that the microswitch need replacing. Other threads here suggest Omron part number D2HWBL221H is the one (pictured below). It has three connections, whereas another picture I saw here looks like it has just two. An answer would be gratefully received! I have not "gone under pedal" yet and would prefer not to until I have the correct part and have summoned up the will to do it! Thanks.
Old Aug 21, 2024 | 05:29 PM
captainobvious1's Avatar
Originally Posted by XK8FAN
Brake lights are stuck on unless I wiggle the pedal, so I assume that the microswitch needs replacing. Other threads here suggest Omron part number D2HWBL221H is the one (pictured below). It has three connections, whereas another picture I saw here looks like it has just two. An answer would be gratefully received! I have not "gone under pedal" yet and would prefer not to until I have the correct part and have summoned up the will to do it! Thanks.
I took mine to Consolidated Auto Works (in Portland, OR.). Have it replaced by a professional and you'll likely never have to worry about it again.
Old Aug 21, 2024 | 07:32 PM
RJ237's Avatar
It probably needs adjusting. The mounting nuts may be loose.
Old Aug 22, 2024 | 02:35 AM
dibbit's Avatar
The original microswitches have three connections. One of the switches is wired up as normally open and the other is wired as normally closed. This means that each switch use two of the three connections, with the third connection unused. As long as the replacement microswitches are the correct dimensions you should be fine.
Personally I would do it the other way around and remove the brake switch assembly before ordering the replacement parts to be sure the replacements are correct. You might even find you don't need new switches.
Old Aug 22, 2024 | 08:39 AM
motorcarman's Avatar
The self adjusting RATCHET is a plastic toothed mechanism.
Adjust the switch assy and your brake switch problem will like be solved.
Richouser
Apr 1, 2021 08:51 PM
Busa
Nov 7, 2018 09:06 PM
DB6
Jun 21, 2011 11:21 AM
mava89
XJ40 ( XJ81 )
Aug 31, 2010 03:54 AM
