Please help with Atlas wheels on a 98 xk8
Greetings, I have my 98 xk8 in the paint shop for a total redo, gonna be awesome! So I decided it needed new wheels, the chrome 17" revolvers needed upgrading.
I wanted to stay with an OEM rim, So upon much research I decided to go with the Atlas Wheels. Well, not so fast. All my research said these wheels would work,
And that all these cars were the same, at least on the wheel lug pattern.....Well they are not! Here's what I know to be true so far, All of the Xk8's were the same....
5 lugs 4.75" 121mm But the Atlas rims came on the XKR's..... Which have a different wheel lug pattern..... 5 lugs but 4.25"
So...to all of you wonderful folk out there please help me if there's anything I can do at this point. The rims are about an inch larger in the back. I can get wheel spacer/lug adapters but they are an inch thick, Is that a possible option? I really apprieciate the help. I plan to reveal this car to the mrs at valentines day! lol But gotta have wheels! lol
Believe me, I rode 500 miles to buy them, I surely never expected them not to fit. Several people have suggested Hub centric spacers.
So I need a spacer to go from my 4.75 to 4.25. Any suggestions about the correct spacers? Thanks so much!
Yep, The XKR wheels were 4.25 the xk8's which I have are 4.75 I'm not sure what my atlas rims come off of, But I think an xkr.
Did they put that rim on anything else? So is x150 wheels another way of labeling the atlas rims? And they set I have are staggard.
Thanks, brian
Thanks, brian
Ok, We are getting there. So I would strongly suggest anyone buying a set of atlas "or any rims" to measure your
studs and measure the rims your wanting.
In the meantime, Do you think 1" spacer-adapters will work?
I see that most people use spacers, but usually around 1/2 inch
Will 1" be too much and will it be a constant nightmare? Thanks
I would not do it. I would find a proper set and avoid the headaches.
If you look for X100 rims, you need 5x120.65, nothing else. The X150 started to have the 4.25. All rim info is always stamped on the inside, such as lug pattern, width and offset. Next time check
On the spacers, I dont see how a half inch is strong enough to hold the additional lugs. There are people happily using 1 inch spacers, it all depends how u want it to look. It also depends on the offset of the rims you bought, they might not clear the fender.
.On the spacers, I dont see how a half inch is strong enough to hold the additional lugs. There are people happily using 1 inch spacers, it all depends how u want it to look. It also depends on the offset of the rims you bought, they might not clear the fender.
Yes! That is the lesson learned here. But this is good info to have out there. Cause one can research for years and believe the atlas wheels were all the same and the lug patterns. Just know there were differences. So, I'm looking for a great set of atlas wheels for the xk8. I'll let you guys know if the spacers are on option. Thanks
FS[SouthEast]: Jaguar XK8 XKR Atlas Chrome Wheels (set of 4) with tires
hm1
Feb 12, 2017 11:57 AM
pomosv
Jan 6, 2013 04:58 PM
Miami XKR
Dec 20, 2011 07:31 PM
Miami XKR
Jan 30, 2011 01:25 PM
