pollen filter housing
Old Mar 14, 2018 | 10:44 AM
rsdmitch7's Avatar
Default pollen filter housing
Looking to buy filter housing for '99 XK8 convt.
Old Mar 14, 2018 | 11:00 AM
fmertz's Avatar
Are you sure?
retro-fitting-cabin-pollen-filter
Old Mar 14, 2018 | 11:32 AM
The pollen filter is perfectly postioned to get soaked and smelly. Jaguar moved them into the engine compartment on the next model to get round this issue.
If CT has a wet climate, then the filter is best avoided.
Old Mar 14, 2018 | 11:38 AM
It looks like way too much trouble, maybe that's why they didn't put them in?
Why would you need a filter on a convertible?
Old Mar 14, 2018 | 03:18 PM
CorStevens's Avatar
when you are driving through a dust storm or the more hygienic areas of New Jersey right as the climate control decides to switch off recirculate because the user cannot possibly be trusted to know when he does and does not want outside air. if it is the last thing that i do, will figure out how to defeat this functionality.
Old Mar 14, 2018 | 03:24 PM
On the S Type if you press and hold the recirc button it will beep (or maybe double beep)
then doesn't change with auto operation.
Does that work on the X100s?
Old Mar 14, 2018 | 03:38 PM
CorStevens's Avatar
thank you, that technique does work on the xk8, however on full auto it is defeated once you reach the temperature setting. additionally, it resets after you turn off the ignition so that you can get a nice intake of unburned hydrocarbons when the blower starts.
i am planning on adding a remote start so keeping this setting matters.
JimC64
Sep 22, 2025 02:52 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
billinohio
Nov 26, 2011 05:54 PM
sjuraud
Aug 28, 2010 02:11 PM
billinohio
Oct 4, 2007 05:10 AM
