power steering fluid check 1998 XK8
Old Oct 22, 2019 | 10:03 AM
klynn's Avatar
Default power steering fluid check 1998 XK8
Seems like a simple thing, but I can't find anything that tells if the power steering cap should be tightened to check the fluid level or just resting on top of the reservoir to check the fluid level. What is the proper way to check the fluid level.
Old Oct 22, 2019 | 10:06 AM
Jon89's Avatar
Screw the cap down into position. Then unscrew it and check the fluid level on the cap's indicator stem.
Old Oct 22, 2019 | 12:00 PM
klynn's Avatar
Various fluid level checks have different procedures so I have never been sure about this one.
Old Oct 22, 2019 | 12:18 PM
motorcarman's Avatar
And the cap does NOT need to be tightened 'gorilla-tight'.
Seems like everybody thinks it will leak unless it is so tight you tear the mounting grommets to get it off!!!!!!!!!!
SNUG IS GOOD.
bob
MMM
Jul 8, 2022 01:49 PM
orangeblossom
Aug 30, 2017 08:12 AM
brgjag
Jan 15, 2016 02:45 PM
funkdoktor
Dec 9, 2011 06:14 AM
The Coupe
Oct 15, 2011 07:11 PM
