Preemptive Care For Electrical Systems ?
Old Oct 2, 2024 | 09:55 PM
zray's Avatar
Default Preemptive Care For Electrical Systems ?
Is this a pipe dream ? Or are there any steps that can be taken to extend the life of the various modules, ECM, etc.
I do know there is at least anecdotal evidence that using a battery tender can have some anti-gremlin benefits.
But beyond that, and the common sense items like don’t leave the battery connected while taking out the instrument panel, etc, are there any steps that can help these aging circuits stay healthy ?
if the obvious answer is “no, you fool!”, then just say so. It won’t be the first time I’ve tried to bend reality.
Z
Old Oct 2, 2024 | 10:06 PM
wymjym's Avatar
Z
Other than buying 'new' replacements, placing them in a descacant filled bag and putting that in a refrigerrator (or at 40 f) for future use!
wj
Old Oct 3, 2024 | 03:28 AM
RichardS's Avatar
I've no idea whether my thinking on this issue has any relevance to modern cars but it certainly applied to my cars in the 1960's and 70's and that relates to the growing trend of washing the engine bay with soap and water or even a power-washer. There are plenty of videos on YouTube which demonstrate this practice. I've never done this as my feeling is that potentially encouraging water to enter places where it might not otherwise enter is never going to be a good idea.
A wipe over with a cloth dampened with degreaser is all that is required although it does take a bit longer than a blast with a power-washer. I don't know about steam cleaners as used by some YouTubers as I've never owned or used such a device but if the steam enters an electrical component and then condenses inside, as it surely will, then it doesn't sound like a great alternative?
Richard
Old Oct 3, 2024 | 03:44 AM
Pistnbroke's Avatar
Taken my dash out 4 or5 times an never disconnected the battery . ( to get the SRS light to go out)
With the ECU you could change the capacitors after 25 years and or inspect for capacitor leakage which can bugger the circuit board.
Like previous dont get things wet.
Old Oct 3, 2024 | 07:22 AM
michaelh's Avatar
+1
Water and electronics don't play well, especially when:
a) the water isn't pure and;
b) the electronics are powered.
“There are naive questions, tedious questions, ill-phrased questions, questions put after inadequate self-criticism. But every question is a cry to understand the world. There is no such thing as a dumb question.”
Carl Sagan
Old Oct 3, 2024 | 07:30 AM
Jon89's Avatar
I agree with not using pressure washers or garden hoses in the engine bay. It simply is not worth the risk....
Old Oct 3, 2024 | 08:37 AM
zray's Avatar
“…….With the ECU you could change the capacitors after 25 years and or inspect for capacitor leakage which can bugger the circuit board……”
a non invasive quick visual of circuit boards to check for leaking or bulging capacitors sounds like a great way to head off a more expensive repair that would be sure to happen
Old Oct 3, 2024 | 09:35 AM
dibbit's Avatar
I strongly recommend that if you want to check for bulging capacitors you do what I did and buy a spare module and open the spare one up to look, rather than unplugging your fully working ECM complete with 20+ year old wiring harnesses and opening up a metal box that has been sealed since it left the factory.
If your electrics don't have gremlins, do your best not to add any.
This is the inside of the spare ECM I bought - it looks like it left the factory yesterday:-
Old Oct 3, 2024 | 11:13 AM
zray's Avatar
i do understand the need to not
break what is working fine,
but is looking at a spare part going to inform you whether there’s a problem on the horizon with the installed part ? The spare is not going thru heat cycles anymore.
If opening up the ECM could keep a potential issue from becoming a major problem and ruining a circuit board, there’s a school of thought that says to do a visual check .
Especially on cars with a lot of mileage or those being driven for hours at a time on a long trip, where the electronics will get hotter for a longer period of time.
I don’t have any answers, just questions.
Z
PS if you don’t mind sharing, how much did that spare ECM cost ?
Old Oct 4, 2024 | 03:32 AM
dibbit's Avatar
Well the spare ECU came from a car breakers, so is the same age as the one on my car and will have no doubt done a higher mileage than my low mileage car, so similar usage. I thought it would be informative to see what it looked like internally and I was very reassured how good everything was looking. I paid about €200 ​​​​​(= $220 USD) for the spare, which seemed to me cheap insurance.
For pre-emptive maintenance I think the computer cooling fan would be worth checking/changing. Maybe we should add a temperature gauge to the computer box so we can keep an eye on that as a precaution?
Old Oct 4, 2024 | 10:02 AM
zray's Avatar
Interesting you should mention the CPU cooling fan.
when I drove 400 miles to Iowa to check out the XKR I subsequently purchased, on the first test ride I had the owner drive it so I could concentrate on noises and vibrations.
Right off the bat a loud squealing noise came from the engine area. It was LOUD.
The owner turned pale, thinking he’d lost a sale. But I assured him I wasn’t scared off yet. Looking under the hood I could tell the noise wasn’t from the engine’s internals. And it went away after a few seconds. I figured correctly it was a cooling fan.
After the 400 mile trip back home on ice covered highways I did some examination and pulled out the intermittently bad fan in short order. In a couple of days SNG Barratt had a new fan delivered and it’s been trouble free ever since (about 7 years so far).
Z
Old Oct 5, 2024 | 03:14 AM
dibbit's Avatar
The funny thing is I've replaced lots of CPU fans in computers because the bearings have failed, but would never really think to check the ECU fan is working on the car - you are lucky it was making itself known by screeching away at you.
Old Oct 6, 2024 | 01:19 PM
clubairth1's Avatar
Community Influencer
Interesting because I have started to lubricate those bad computer fans. They have a sticker or a small rubber plug over the bearing. Remove that and put a tiny drop of lube on the bearing. Replace the sticker or rubber plug.
After the first couple it I did it became very fast to do. I have a work station with about 6 fans in it and it got so bad it was in constant re-boot failure mode and I was considering throwing the computer away as it was old. Plus the noise the fans were making convinced me they were shot. After the lubrication and blowing out about 3 pounds of dust and lint and cat hair the machine works perfectly and it surprisingly quiet!
Old Oct 7, 2024 | 03:24 AM
dibbit's Avatar
Now that would be a very good bit of pre-emptive maintainance to keep the original German made fan working, rather than replacing it with something from China. I wonder if Zray (or any forumites) kept their OEM fan and could peel the sticker back to see if the bearing is accesible like this?
Old Oct 7, 2024 | 03:41 AM
zray's Avatar
I’ll look for it. The replacement one I bought from SNG Barratt came in a Jaguar box and is supposed to be exact replacement , not aftermarket look-a-like
Z
Old Oct 8, 2024 | 05:51 AM
TGraves's Avatar
Default Electronics failure
My experience with electronics, from auto to FM broadcast, is that electrolytic capacitors (the small can devices in circuitry) don't like long periods of no use. The varying voltages they operate under helps preserve the electrolytes. Over time, these caps do fall out of spec, so they'll almost always need replacing. As far as inspection, a ruptured cap can do far more damage than opening a sealed unit for inspection, so I wouldn't hesitate to open an ecu if it starts acting flakey, even before.
My experience with equipment is that pressure washers can drive moisture into connectors , especially if one isn't up to spec. The owner's manual of newer equiptment often recommends no more than 50 psi should be directed at any wiring, even on ag equipment that is built to operate in harsh conditions.
Since relays and switches arc slightly at every use, I am of the belief that most highly used relays should be replaced every so often to avoid low voltage/intermittent contact problems.
One of the best things you can do is drive these cars. Turning on options, especially AC and run till thoroughly warmed up. Greases loosen up and seals get a little flexing.
My 2Cents!
Old Oct 8, 2024 | 06:00 AM
Jon89's Avatar
Agreed. The best way to keep these cars happy and healthy is to drive them regularly....
Old Oct 8, 2024 | 11:39 PM
zray's Avatar
I’ve owned a lot cars and motorcycles over the last 60 years. More than I can care to list. Not too many characteristics are shared by all of them.
But this is one of few areas of commonality: cars that are driven infrequently, or come to me as “garage queens” are always more trouble to own and operate..
Cars that are driven often and over long distances are always more reliable. They are proven.
low mileage cars ? Not for me, no thanks.
I’ll buy a vehicle that’s proven its reliability by racking up the mileage every time over those “desirable” low mileage cars. It took me a couple of decades, but it finally sunk in to avoid low mileage garage queens like the plague. Before coming to that conclusion it usually took me a couple of years of continual minor repairs before the car was reliable and I could travel anywhere without worry.
Many times I’ve read on this forum, and others, of someone who just joined and is posting beautiful pictures of their new low mileage acquisition. The are pretty no question about that.
But It’s not too long before that same person is wondering why this or that has gone wrong, as that shouldn’t be happening given the low mileage.
It’s the plain truth that the problems these cars have nothing to do with the miles accumulated. And everything to do with poor maintenance or disuse.
Z
DanoldKong
Jul 10, 2023 11:24 PM
Robin Gaudreault
Apr 27, 2023 10:59 AM
sogood
Dec 13, 2015 07:50 PM
thedebs53
May 2, 2015 03:27 AM
BradMilton
Jun 15, 2010 09:26 PM
