Preferred tire pressure
Old Jan 14, 2018 | 01:14 PM
zray's Avatar
Default Preferred tire pressure
Just looking for some feedback regarding members preferred tire pressure. My owner's manual gives a range of pressures to be used, depending on how fast the car is going to be driven.
What psi is working best for you ?
The opportunities for safely driving over 100 mph are becoming few and far between these days. So I'm hesitant to keep my tires inflated for high speed (+ 100 mph ) driving . I did manage to briefly venture into triple digit mph territory on my way home from Austin last Friday, but only for a few seconds. Those triple digit circumstances are likely to be rare, if ever again. So should I let some air out of the tires as the manual suggests, for enhanced comfort ? Will steering precision suffer ?
Old Jan 14, 2018 | 03:28 PM
RJ237's Avatar
I always am more concerned with tire wear. 32/34 worked just fine on my '97, but the R and later xk8 with larger rears often experience center wear unless they drop to 32 or even 30 at the back.
Old Jan 14, 2018 | 09:26 PM
Jandreu's Avatar
I run 29 ft 26 rear and get exceiient even tire wear, however I do no long distance driving, most I get is 15 miles at a time.
Old Jan 15, 2018 | 06:46 AM
Jon89's Avatar
My wife's 2006 XK8 does best at 32 to 33 psi in front and 28 to 29 psi in back (on 19-inch Atlas rims). These pressures allow for the longest treadwear and are also comfortable and safe for her. I spent the first twelve months of vehicle ownership adjusting the tire pressures before finally deciding on these settings....
Old Jan 15, 2018 | 09:53 AM
RJ237's Avatar
Thanks Jon, I was going to PM you to see how they were holding up since I have the same car now.
Old Jan 15, 2018 | 09:56 AM
Johnken's Avatar
Z7ray, she seems to be happiest at 32 34 for my xk8.
Just in case you never thought of this ( it took me 55 years to realize it) virtually nothing off the shelf in say an auto part store has respectable accuracy or precision. 5 to 10% error is common. I found a gauge on Amazon with 0.5% accuracy for around $30. Hope it helps.
BTW I agree with the spirit of your question. A pound or two makes a noticeable difference in handling and ride.
John
Old Jan 15, 2018 | 10:11 AM
Originally Posted by zray
..... My owner's manual gives a range of pressures to be used, depending on how fast the car is going to be driven. .....
It also gives a range of pressures depending on the wheel size. The optimum pressure for an 18 inch doesn't necessarily apply to a 19 inch or 20 inch.
ddillenger
General Tech Help
Jul 23, 2019 06:27 PM
ETexJag
Feb 26, 2015 08:56 AM
Valander
Jul 11, 2013 03:32 PM
Todd951968
Nov 4, 2012 11:23 AM
Xkat98
Oct 16, 2012 07:27 PM
