Question about disconnecting battery
Old Aug 18, 2013 | 10:45 AM
krswen's Avatar
Default Question about disconnecting battery
I'm launching a deep cleaning campaign on my new 2004 XK8. I plan to remove the seats and I've read that it is prudent to disconnect the battery so the airbags don't inadvertently deploy. Will that do anything to the stock radio? Will I need to enter a security code upon repowering? I don't have the code ... it was never entered in the Passport to Service book. If I need it, is it stamped, or on a sticker on the radio chassis?
Ken
Old Aug 18, 2013 | 10:49 AM
WhiteXKR's Avatar
Ken
Disconnecting the battery is prudent when anything electrical in the car is disconnected/reconnected.
The vast majority of US cars do not need the radio code. If you happen to have one of the very few that does, it can be obtained from a Jag dealer with a VIN number and proof of ownership.
You will need to reset the windows when you reconnect the battery. Instructions are in the owners manual and also on the forum in dozens of posts.
Old Aug 18, 2013 | 10:50 AM
jimbov8's Avatar
Hi Ken,
You should have a radio hand book, if you do need a code then it will be in there on a credit card sized card.
I don't think the US cars need a code though.
Old Aug 18, 2013 | 01:48 PM
Only a very small number of US members report having coded radios fitted. It came as a surprise to me that any do as this was specifically a UK market measure supposed to deter thefts.
You'll need to do a little more than just the window travel limits after a battery disconnect or 'hard reset' on a 2004MY. Full details in this thread:
https://www.jaguarforums.com/forum/x...connect-74146/
Nothing difficult.
Old Aug 18, 2013 | 06:48 PM
rothwell's Avatar
I just had the seats out of my 04 XK8 today to clean the carpet and fix both headrest drive cables.
After reconnecting the battery I only had to run the windows down/up and hold the button a few seconds till you hear the click.
Then had to run the top up/down so the rear windows would adjust same way.
Radio still works!
Old Aug 18, 2013 | 08:44 PM
Paul Pavlik's Avatar
Originally Posted by rothwell
Radio still works!
Some of the Audio Presets may need to be Reset (Subwoofer Level , Bass & Treble and Balance).
Old Aug 27, 2013 | 08:21 AM
1951sms's Avatar
Default radio codes
Would my 1998 XJ8 fall into one of the cars that don't need a security code?
Forcedair1
Sep 8, 2025 01:57 PM
philwarner
Oct 4, 2024 01:37 PM
Dagny
Jun 11, 2024 01:06 PM
SeanU
Sep 13, 2015 02:45 PM
DEklof
Sep 8, 2015 05:28 PM
