Question about Stability control failure / ABS warning
4 days ago I got caught in a heavy rainstorm.. Drove through deep puddles for about 2 hours..
The next day after a 10 mile highway run, the stability control failure warning and ABS light come on.
I pull over to my destination, turn the car off.
I come back an hour later, start the car and go home
The warning or ABS light have not been on since 3 days now.
Your thoughts?
Your thoughts?
The wheel speed sensors can get dirty and/or wet. Only a small screw holds each one in place. The two on the back are accessible above the inside of the wheels, two on front can be removed for cleaning from the forward part of the wheels. Once removed, use soap and water to get the grime off while covering the electrical connection with a finger to keep it relatively dry. May have to go through a few trips before the light goes off.
Johnken (07-11-2017)
The wheel speed sensors' wiring harness rubber boots tend to crack and split as the years go by, allowing moisture into the wiring harnesses. I discovered this the first time I pulled the sensors (in March 2013) to scrub them clean after my wife complained about ABS/DSC warnings randomly appearing on the dash. To fix the boots, I purchased a tube of neutral-cure RTV silicone sealant, cleaned the cracked and split boots, dried them thoroughly with a hair dryer, then applied a generous amount of the sealant all over and around the boots, ensuring that I spread enough sealant over each boot to seal all cracks from the elements. I kept the car on jackstands overnight and allowed the sealant to cure for 24 hours before I plugged the wiring harness rubber boots back into the sensors. That ended the random ABS/DSC warnings on the dash - my wife has not reported seeing them since....
I continue to pull and clean the wheel speed sensors at every oil & filter change / tire rotation (6,000-mile intervals). I inspect the condition of the rubber boots each time, and if my silicone sealant "glob" appears to wearing off, I gently clean it up with some of the same dish soap & water I use to scrub the sensors, dry it thoroughly, and add more sealant. I have had to add more sealant at least once and maybe twice since March 2013. Well worth the effort if this process keeps the ABS/DSC systems happy....
Received 2,184 Likes
motorcarman (07-11-2017)
Not everyone can read those codes, and travel to a shop with the software may take more time than doing some basic maintenance, not to mention the cost of diagnostics.
My own opinion is that if you're going to mess with aging Jags you should invest in the software. I think there are inexpensive smartphone apps that can read all the codes now.
not everyone can read those codes, and travel to a shop with the software may take more time than doing some basic maintenance, not to mention the cost of diagnostics.
My own opinion is that if you're going to mess with aging jags you should invest in the software. I think there are inexpensive smartphone apps that can read all the codes now.
