question on front lower wishbone bushings
Old Jul 15, 2018 | 05:02 PM
Veteran: Navy
Default question on front lower wishbone bushings
I plan on replacing the remaining suspension bushings on the car and already have the needed powerflex poly bushings But in reading the remove/replace for the front lower wishbones, it has you remove the steering rack. If I simply disconnect the tie rod ends - since I found those in need of replacement this weekend - will that give me enough clearance to remove the rear bolt for the lower wishbone
Old Jul 15, 2018 | 05:45 PM
rothwell's Avatar
You should not have to completely remove the rack.
Just remove the 4 bolts that hold the brackets around the rubber rack mounts so you can move the rack a bit to get the control arm bolts out.
This article covers it.
XK8 Front Suspension How To
* If you haven't done the wheel bearings or ball joints now would be the time since to consider it since you are disconnecting so much already.
Old Jul 15, 2018 | 05:49 PM
Veteran: Navy
excellent!!! many thanks!!!
Old Jul 16, 2018 | 01:30 AM
rothwell's Avatar
I should have mentioned that the rubber rack mounts were not expensive. I would replace them (if they are original) since you will have them loose anyway. New rubber will better insulate vibrations.
Old Jul 16, 2018 | 03:09 AM
DevonDavid's Avatar
The bolt can be removed without moving the steering rack. With the rubber gaiters unclipped and slid back towards the wheel end of the rod, and with the steering on full lock, there's just enough room to manoeuvre the bolt out. This can be the better way if there's corrosion on the rack mounting bolts and any concern about shearing them off.
blindside
May 17, 2018 09:34 AM
Jag#4
Jun 27, 2016 08:47 PM
Steve-in-ct
May 21, 2016 08:52 PM
TreVoRTasmin
Oct 27, 2014 06:08 AM
shl1980
Aug 14, 2012 06:04 AM
