Radiator drain
Old Sep 13, 2018 | 03:56 AM
skymark's Avatar
Default Radiator drain
Mine is a 1999 4.0 and I need to drain the cooling system and can’t seem to locate the drain plug my manual says is on the bottom or the radiator.
Old Sep 13, 2018 | 06:41 AM
Bottom RH corner on the back of the radiator (see item 1):
Old Sep 13, 2018 | 07:45 AM
fmertz's Avatar
Use your best judgement on this. This plug is plastic on a plastic end tank, and lives in a recessed area a bit hard to reach. Nobody has reported a way to drain the car without making a mess. Coolant seem to get on horizontal surfaces and travel. Have a big catch container available (and no pets around). There are other options, like the lower radiator hose, or even the engine drain. What procedure are you performing? If the work is high enough, you can get away with draining the expansion tank with a turkey baster type tool and deal with a bit of overflow. Your call of course.
Best of luck, keep us posted.
Old Sep 13, 2018 | 08:52 AM
Jon89's Avatar
^^ What he said. I would not attempt to unscrew that aging plastic drain plug. It may crack and break. Far less risky to pull a lower radiator hose and drain the system that way....
Old Sep 13, 2018 | 09:22 AM
motorcarman's Avatar
You can drain without a BIG mess but there will be 'splashing' and drops in a wide pattern.
I lift the car and place a plastic dealer tag (license plate insert) into the front suspension crossmember.
The stream of coolant hits the plastic plate and it drains into a LARGE transmission funnel on a transmission jack.
Just the way I do it, but I have car lifts. It is a little more difficult on jackstands. Not as much 'maneuvering-room'.
You will need a LARGE, long screwdriver to turn the plug.
bob
Old Sep 14, 2018 | 06:48 PM
skymark's Avatar
Default Reply
Gentleman thank you for sharing your experience and insight on this issue. This all started because I smelled a faint whiff of coolant from time to time and finally located a leak where the metal thermostat housing mates withe the hose manifold piece. Mine has a gasket and I think the PO added. The rubber seal is supposed to be the only sealing method so I’m going to correct it. My thinking is since I bought this car a few months ago now would be a good opportunity to change the coolant. I have a V12 XJS that I just drill a hole in the lower hose drain the fluid then replace the hose. Minimal cost and less mess. It would appear this maybe the same here. I have the hoses in stock so that will be the best option.
I would like to explore removing the plug and installing a quick drain that I could attach a hose to for future consideration.
J_C_R
Mar 25, 2013 08:07 PM
Per
Dec 7, 2012 01:57 AM
Jag69
May 22, 2012 01:17 PM
dneider
Dec 13, 2011 10:11 AM
ronmexico
Nov 10, 2009 02:13 AM
