Re Chrome main beam reflectors (UK)
Old Oct 25, 2022 | 01:10 AM
Pistnbroke's Avatar
Default Re Chrome main beam reflectors (UK)
Have needed one of my main beam reflectors re chromed for some time but the nice MOT man has passed it twice with some aluminium tape over the lower half. Re chrome prices were stupid until I found this .
sales@chromefix.co.uk who replied...
We can strip, polish and re-chrome the part for £40 + vat (our minimum charge) + P&P -£ 9.95 +vat via fed-ex tracked next day delivery .
If that min charge would cover two I dont know .....over to you its in Birmingham.
Old Oct 25, 2022 | 04:23 AM
Robin Smith's Avatar
Looks like a good find but not sure they will do the X100 headlight reflectors as I think they are plastic.
The other issue is separating the glass lens from the reflector as they are bonded together.
Old Oct 25, 2022 | 06:41 AM
Pistnbroke's Avatar
Dont think its plastic as it seems to have a rolled edge....Its 3.5 in Dia and I have found a 4 in metal reflector which I may try to tiim down and put a 1/2in hole in the back then thread it over the bulb and stick it in with silicone.
Pattern is largely unimportant for the main beam as long as it looks shiny for the MOT man
Old Oct 25, 2022 | 08:24 AM
wymjym's Avatar
Just to be clear, please point out which portion is the main beam
thankyoi
NorXKR's Avatar
You dont need to separate the glass to get access to the high beam reflector
Old Oct 25, 2022 | 08:33 AM
Pistnbroke's Avatar
Nor XKR ..tell me more I assumed ..remove headlight unit ..take off front glass access high beam reflector .
Having spent time with my hand inside the lamp unit fitting HB3 bulbI dont see any other way.
Old Oct 25, 2022 | 09:09 AM
Ah OK, you're talking about the main (high) beam reflector. This may well be metal as it is separate from the glass and reflector sub-assembly. My reflector is more black than chrome in the ridged area on this sub-assembly so I'm keeping an eye out for solutions to this problem. There are some useful videos on this subject here (https://www.tothegarage.co.uk/services-2)
Old Oct 25, 2022 | 10:34 AM
Pistnbroke's Avatar
Black, Ridged ? what ar you on about ....??? The chrome trim within the headlamp unit ?
Old Oct 25, 2022 | 11:00 AM
Yes, see picture below (with thanks to wymjym), on my LH headlight the circled area has lost most of its reflective surface.
Old Oct 25, 2022 | 03:53 PM
Pistnbroke's Avatar
none of that area is important..it has nothing to do with the beam pattern just cosmetic
Old Oct 25, 2022 | 04:11 PM
wymjym's Avatar
that is incorrect, the veined area diffuses the light
wj
Old Oct 25, 2022 | 06:47 PM
NorXKR's Avatar
Some confusing here....
The main beam reflector is steel not plastic (I've just tested it with a magnet)
The reflective plastic that is bonded to the glass lens is another thing.
You dont have to remove the glued glass to get access to the MAIN BEAM reflector.
The headlight assembly is made up of two parts that are just snapped together, the rear part witch hold the main beam reflector and low beam projector, and the front part with the glass glued to the reflective plastic part.
In US (or some states) they want to diffuse some light upwards to light up overhead traffic signs. I dont think that relates to any country in Europe.
I have painted mine black, and it will do nothing to the actually beam pattern or light output on the road.
paulyling
Jul 19, 2014 07:55 PM
Adam Lueb
Jun 6, 2011 03:23 PM
Adam Lueb
May 5, 2011 10:56 AM
CarSmartNot
Exterior
Apr 20, 2010 06:42 AM
