Rear Back up sensors keep beeping in reverse when nothing is back there
Old Dec 16, 2022 | 06:00 PM
Pantera928's Avatar
Default Rear Back up sensors keep beeping in reverse when nothing is back there
Rear Back up sensors are beeping frantically whenever the car is in reverse. Nothing on them and no sign of damage
Any ideas?
Old Dec 16, 2022 | 06:26 PM
zray's Avatar
Mine do that when they are dirty.
Z
Old Dec 16, 2022 | 06:41 PM
Pantera928's Avatar
That was the first thing I checked. Thanks
Old Dec 16, 2022 | 09:03 PM
zray's Avatar
about every 100th time, or more rarely, when I’m putting the car in reverse for the first time of the day, I will get the spurious warning for seemingly no reason at all, even with clean sensors. After that first false alarm the sensors will behave. And it only happens every 3-4 months at most.
The false alarm hasn’t happened in quite a long while.
if you get your issue sorted out please report the results.
Z
Old Dec 16, 2022 | 09:14 PM
Pantera928's Avatar
I will definitely share any knowledge I learn on this and any other XK8 issue.
Old Dec 23, 2022 | 09:39 AM
Dr. D's Avatar
Pantera928
While backing in reverse, each of the 4 backup sensors in the rear bumper normally emit a very slightly audible clicking noise. Are we to assume that all 4 indeed are clicking; else, any sensor not clicking denotes a failure and will cause the backup alarm to beep constantly while in reverse?
Old Dec 23, 2022 | 11:44 AM
JayJagJay's Avatar
Originally Posted by Dr. D
Pantera928
Yup! And going in to check on em ain't much fun.
Old Dec 23, 2022 | 03:09 PM
Dr. D's Avatar
I definitely agree, but I, as are some others, are somewhat more fortunate to have factory access holes in the metal bumper core for the two inboard sensors.
While I cannot speak for all X100's, the 2 "right angle" outboard sensors and the 2 "straight" inboard sensors are complertely interchangeable on my 2002 XKR Conv.
(I did purchase a "right angle" that I was able to install inboard.)
Old Dec 24, 2022 | 12:27 PM
Pantera928's Avatar
Agreed as that is typical of all ultrasonic sensors. Unfortunately or fortunately, the system started working properly before I could check.
We will see what it does in the future
Ant Buck
Jul 27, 2022 04:14 PM
Donna
Mar 11, 2014 09:46 AM
Baby_Jag
May 7, 2010 06:13 PM
carelm
16
Feb 2, 2010 12:38 PM
rscultho
Sep 3, 2008 04:05 PM
