Rear bumper lights
Old Mar 25, 2021 | 10:13 AM
alanroberts50's Avatar
Default Rear bumper lights
Hi does anyone know how the bulb is replaced? Does the whole red plastic piece have to come out or is it a case of reaching up behind the bumper and the bulb holder just twists out?
thanks
Old Mar 25, 2021 | 11:24 AM
Johnken's Avatar
Wish you had been more specific. Let me try to help.
Reverse
Brake
Turn
Lights accessed through trunk. The bulbs are in a common pod that is released from the trunk side. I think the pod (light sockets soldered onto a circuit board, in a plastic housing) is secured with plastic tabs. Either way, its obvious when you look.
John
Old Mar 25, 2021 | 12:50 PM
NorXKR's Avatar
Side marker lights? Push the hole lens assembly forward and at the same time pry it out at the back.
Old Mar 25, 2021 | 02:05 PM
the red lights in the bumper. If they are called the side marker lights then yes, thanks I will give that a try. Then the bulb is a twist out type?
Old Mar 26, 2021 | 04:25 AM
The relevant page from the Driver's Handbook:
If you don't have the Driver's Handbook, the full Vehicle Document Set is available for download from this thread:
https://www.jaguarforums.com/forum/x...006-faq-67827/
JCalhoun
Jan 29, 2020 10:25 AM
carsnplanes
Oct 29, 2018 07:11 PM
AlbBolivar
Feb 24, 2014 03:37 AM
wolv2401
Feb 21, 2010 11:09 PM
solidx
Aug 12, 2008 10:55 AM
