rear bumper mount aluminium corrosion
Old Jul 31, 2014 | 02:12 PM
RaceDiagnostics's Avatar
Default rear bumper mount aluminium corrosion
This is my second bumper mount to have gone this way, I wonder if it is possible to machine a new part to fix the problem.
Kim seemed to think a strong alkaline solution would dissolve the aluminium oxide.
So a bit of hot water and a sprinkling of the caustic soda crystals gave this.
30 mins later it is still fizzing away.
More pics later. I'm thinking, use a length of pipe with a bracket welded on to replace the outer part, forget the screw adjustment and provide that adjustment with washers.
Old Jul 31, 2014 | 03:02 PM
Isn't it great when a plan comes together.
Just need to trim the pipe and weld on a couple of small brackets.
Old Jul 31, 2014 | 04:52 PM
rothwell's Avatar
Nice Work!
Old Aug 1, 2014 | 03:56 AM
As always - very enterprising.
How are you planning to adjust the insert height? Using replacement brackets, I had to set them at nearly an inch on my 2001 XK8 to get the right clearance on the bumper gap:
Liberally coated in Coppaslip before finally refitting the bumper.
Old Aug 1, 2014 | 04:20 AM
My car needs about a 2 to 3mm adjustment, I have two plans, one, use a large washer and enlarge the hole to fit between the top of the pipe and the adjuster, or find a plastic sleeve that I can fit between the inside of the pipe and the threaded adjuster. if I can get the perfect bit of softish plastic I think that the adjuster will be able to cut a thread into the plastic packer/sleeve and then still be able to work as intended.
FrickenJag
Jun 16, 2025 02:15 PM
H20boy
Dec 24, 2024 03:23 PM
AlexSaltLife
Jan 23, 2023 10:41 AM
EZDriver
Sep 8, 2015 09:25 AM
prettydaim
Sep 4, 2015 09:13 AM
