Rear bumper parking sensor - how to remove?
Old Jan 15, 2013 | 05:18 AM
Frog's Avatar
Default Rear bumper parking sensor - how to remove?
I received my new rear parking sensor this morning, but I can't work out how to remove the old one. It pulls out fine about 1", but then gets stuck. The problem is that I'm doing everything by touch, as the main cross member prevents me from seeing what's in there. I looked for a how-to, but couldn't find one.
Any ideas?
Old Jan 15, 2013 | 05:53 AM
XKRacer's Avatar
They are on a bayonet style fitting, hold the outer housing push the sensor out on its spring and twist ANTICLOCKWISE then pull back, dont twist clockwise you will break the tabs off.....
Old Jan 15, 2013 | 06:10 AM
Frog's Avatar
Thanks, Tony. I will give it a go
Old Jan 15, 2013 | 07:45 AM
Frog's Avatar
90 minutes later... hey, it works. Just painting the new sensor now... Many thanks, Tony
Old Jan 15, 2013 | 08:03 AM
steveinfrance's Avatar
Now in the How-Tos - thanks guys.
Old Jan 15, 2013 | 09:29 AM
Frog's Avatar
Just to add to Tony's reply, you in fact have to split the sensor into its two component parts while it's in the bumper to release it: push the whole assembly about 1" out of the bumper from inside (it's spring loaded), grip the outer tube with one hand and the sensor inside the bumper with the other hand and turn the outer tube anticlockwise through about 45°. Mine was quite stiff and I had to put a pair of rubber gloves on to get enough purchase, but it can be done with a little persuasion.
The whole assembly then comes apart, allowing you to pull the outer tube away from the back of the car and pull the sensor inside the bumper. Then you just need to get under the bumper and unplug the connector to free the sensor.
Old Jan 15, 2013 | 10:11 AM
That will update the How-TO ,great.
Old Jan 15, 2013 | 10:27 AM
H20boy's Avatar
I've done this too, and its hard to describe. A pic is worth a thousand words...when assembling, grab your camera or phone frog?
tberg
Sep 7, 2015 07:32 AM
KarimPA
Sep 3, 2015 07:32 PM
davidladewig
Sep 3, 2015 06:32 PM
innzane
Sep 2, 2015 10:08 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
