Rear Damper Lower Bush replacement
Had an annoying rattle on left rear for some time.
Yesterday replaced lower damper bush - swine of a job, took six hours.
Real pain getting spring out had to force hub down with a bar in order to get spring and damper assembly out.
Is this normal - I guessing there's an easier way, should have asked before doing job I know - just curious now!
Tony.
Tony.
In post #6 member motorcarman describes an easier way. Never done it myself, but if anyone knows the best way to do something on these cars it would be him.
https://www.jaguarforums.com/forum/x...shocks-146663/
You don't need to remove the damper to change the bottom bush - undo the bottom bolt and it will drop down far enough to enable changing the bush. You'll need a couple of suitably sized sockets and a length of HT threaded rod to press the old one out and the new one in.
WhiteTardis
Mar 14, 2020 05:08 AM
zak
Oct 13, 2015 11:46 AM
