Being told by my independent garage in Georgia USA that need to replace rear differential oil gasket to stop leaks, but the part has been discontinued.
They are proposing using a sealant instead -- Permatex PERMATEX® Ultra Black® Maximum Oil Resistance Gasket Maker.
Does this work, or is it an issue?
Car is a 2005 XKR convertible with 43k miles.
Do they not know what a ball pain hammer is for when used with gasket paper ....
Easy to knock one up ( thats a joke) So what is the ball shaped bit for ??? Answer Making Gaskets
Successfully changed/replaced differential oil.
New problem is Check Engine Light. To resolve it have replaced a couple of leaking air hoses, but so far does not fix issue of "intermittent restricted performance/constant check engine light" and I do not sense a change in performance while driving. After each repair visit, will drive for 30 minutes, turn off, rest for 5 mins, restart, drive again, turn off, restart, then get the restricted performance/check engine light. Mechanic getting "running lean" code, but about a year ago, it pulled code P0456, which is evap issue, I believe. Should next move be to replace fuel filler cap? I trust mechanic, and there is no one else available (dealership declines to help because of age of vehicle -- 2005 xkr convertible, 45k miles). Just wandering in the forest!!
