Rear main seal removal
Old Feb 17, 2015 | 09:28 AM
johns55's Avatar
Default Rear main seal removal
I have a thread going on my xk8 project, but I need some help from anyone who has replaced the rear main seal. I have the tranny out but don't know if the special tool is needed to remove the seal or if anyone has done this with another method. Any help would be appreciated.
Old Feb 18, 2015 | 02:14 PM
palantir's Avatar
There are tools available, Jaguar JD229 or Land Rover 303-538 or Laser 6133. It is for removal & installation, basically consists of a cup, three bolts, six self tappers & a cute little thing to make holes in the seal.(laser obligingly give a nice picture of the set, sooo, if your good with tools).....
Old Feb 18, 2015 | 02:19 PM
palantir's Avatar
Points to note is keep pressure on the seal for a few seconds once fitted & ensure parallel with rear face of housing within 0.012 inch (Oh & remove seal protector once fitted - yes I know, but someone tried to leave it on!!!)
Old Feb 18, 2015 | 10:15 PM
johns55's Avatar
Thanks, the tool is hard to source and pretty expensive. I called Christopher's foreign car parts and talked to Chris. He said they don't use the official tool. They use a punch and then a couple of metal picks to ease it out. I'll try that (without marring the outside surface of the camshaft.
Old Feb 18, 2015 | 10:16 PM
johns55's Avatar
Good info. I could easily make that mistake
Old Feb 19, 2015 | 04:19 PM
palantir's Avatar
Use a sharp pick to pierce the seal at three & nine o'clock screw in a couple of longish sellf tappers & it should pull out with two pair of pliers. For installation some just push in fairly easily others I've found fifteen minutes or so in the ice box helps + plenty of lube , maybe a piece of tubing of the correct diameter to tap it down evenly.
Old Feb 19, 2015 | 05:31 PM
johns55's Avatar
What kind of lube do you suggest? Oil?
Old Feb 19, 2015 | 08:47 PM
palantir's Avatar
Oils fine.
I tend to use the same as we use Turbine engines which is Crisco ( the white fat not the oil) as its absolutely pure very slippery & burns off without leaving any residue.
Old Feb 22, 2015 | 06:50 AM
johns55's Avatar
Got it out using 4 self tapping strews. Thanks for all the help.
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
sogood
Sep 15, 2015 07:35 AM
Joey T
Sep 3, 2015 05:31 PM
d a
Sep 3, 2015 02:34 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
