rear quarter windows go down when turn key??
Old Jul 3, 2016 | 12:13 PM
97 Xk8 mayhem's Avatar
Default rear quarter windows go down when turn key??
so my top use to work fine then the rear windows wouldnt go up and i started to jump relays to raise them then the latch quit working and i use the allen wrench but now the top stoppped working completely and wont work by the switch and wont work by key in drivers door. and finally the very annoying rear window issue where they go down on their own when i turn ignition and i have to jump relay and once i do they stay up until i get back in and turn key and im currently adding a switch to control rear windows until i can figure this out any help would be appreciated and ive tried reseting top by disconnecting battery for 2 days and ive trying applying force to top while open to trip micro switch and sprayed the header and all visable things with wd-40 to clean used an entire can and ive topped off fluid in pump. replaced fuses and moved around relays unless ive got multiple relays bad i dont know and if this might be a issue affecting it im having problems programming key fob theres no chime and shifter light flashes on third click of brights but no success locking it in
rsq911
Apr 1, 2016 11:23 AM
stevepaa
Mar 30, 2016 06:46 PM
Jagjagplayingup
Mar 29, 2016 03:11 AM
JohnBurns
Oct 19, 2010 02:30 PM
Jun 25, 2005 03:18 PM
